[Mapserver-users] E00 to SHP Conversion Utilities?
Dan Barron
dbarron at ddive.com
Thu Mar 6 14:30:20 EST 2003
Thanks Dave. Unfortunately, I have many many files to convert. I do have a
version of import71.exe dated 9-2002, however I'm not too familiar with it
and the documentation it came with does not mention conversion of e00 to
shp only to adf or arcgrid format. Am I missing something? Also, since I
am looking to do many files, I prefer to automate the process, can
import71.exe work in that context?
Dan
At 01:01 PM 3/6/2003 -0600, Lowther, David W wrote:
>Dan,
>The utility IMPORT71.exe that comes with Arcview is made for this... I'm not
>sure if it is available freely or not.
>If you just have a couple of files Dan send em my way and I'll convert for
>you.
>Dave
> > -----Original Message-----
> > From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> > Sent: Thursday, March 06, 2003 10:01 AM
> > To: Dan Barron
> > Cc: mapserver-users at lists.gis.umn.edu
> > Subject: Re: [Mapserver-users] E00 to SHP Conversion Utilities?
> > Dan Barron wrote:
> > > Does anyone have a suggestion on the best approach to convert E00
> > > files to SHP files? I have tried the FME Suite from Safe
> > Sowftware,
> > > are there other available tools/utilities to accomplish this
> > > conversion?
> > FME is definitely the best option, but the license may be expensive.
> > Unfortunately OGR doesn't support reading E00 files yet,
> > otherwise using ogr2ogr would be a good option too. I'm sure
> > many GIS packages will allow import of E00 and export to
> > shapefiles, but I don't have any to suggest.
> > However, OGR (GDAL 1.1.8) does support reading binary
> > coverages, so you can do the conversion in two steps if you want:
> > 1- Convert your E00s to binary coverages using the
> > 'AVCIMPORT' utility at
> > http://pages.infinit.net/danmo/e00/index-> avce00.html
> > 2- Use
> > 'ogr2ogr' (part of GDAL 1.1.8) to
> > convert the binary coverages to shapefiles. There should be
> > some docs on using ogr2ogr on the OGR website at
> > http://gdal.velocet.ca/projects/opengis/index.> html
> > Daniel
> > Daniel Morissette morissette at dmsolutions.ca
> > DM Solutions Group http://www.dmsolutions.ca/
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
