[Mapserver-users] mapscript
Paul Dymecki millardymecki at sympatico.ca
Fri Mar 14 10:42:27 EST 2003
Thanks on both counts,
    I already tried the call you mentioned but the script seems to die when
i include any mapscript code ie. includeing the following line crashes the
script:  My call looks like this: (c:\>php -q myProg.php hello) ,but hello
never gets printed to the screen when the lines previous to the argv call
are included.
Paul
if (PHP_OS == "WINNT" || PHP_OS == "WIN32")
dl("php_mapscript_36.dll");
else
dl("php_mapscript.so");
$map = ms_newMapObj("tutorial.map");
$argv = $_SERVER['argv'] ;
echo $argv[1] ;
thx,
Paul
----- Original Message -----
From: "Daniel Morissette" <morissette at dmsolutions.ca>
To: "Paul Dymecki" <millardymecki at sympatico.ca>
Cc: "MapServer List (E-mail)" <mapserver-users at lists.gis.umn.edu>
Sent: Friday, March 14, 2003 9:54 AM
Subject: Re: [Mapserver-users] mapscript
> > Paul Dymecki wrote:
> >     I was wondering if anyone has tried running mapscript code from a
> > php prog running through the command line?  I'm trying to call a
> > php-mapscript program from perl, and not sure what the best approach
> > would be?
> Yes, that's possible.  Assuming you have a php CGI, you would use:
>   /path/to/php -q /path/to/yourscript.php  arg1 arg2 arg3 ...
> This will run yourscript.php at the command line, and the args will be
> available in the $_SERVER["argv"] array.  The first item in this array
> is the name of the script itself.  The -q option is to suppress output
> of the CGI headers.
>  Daniel Morissette               morissette at dmsolutions.ca
>  DM Solutions Group              http://www.dmsolutions.ca/
