[Mapserver-users] Re: perl / mapscript
Paul Dymecki millardymecki at sympatico.ca
Sun Mar 16 22:25:57 EST 2003
Well actually i may be makeing this more complicated then it needs. I've
built a phpmapscript application containing vegetaion zones(polygons) around
the country.  There is a larger perl application(not under my care) that
will pass me a lat/lon.  I then have to query and return which vegetation
zone this point resides in.  So the script would be a backend one with no
user/map interaction at all.  Would  that be possible.
Paul
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Sunday, March 16, 2003 9:43 PM
Subject: [Mapserver-users] Re: perl / mapscript
> --- In mapserver-users at yahoogroups.com, "Paul Dymecki"
> <millardymecki at s...> wrote:
> > HI Steve,
> >     Do you know if Perl/mapscript is available on windowsXP?
> afaik, perl/mapscript only compiles on unix (I believe these a
> swig-related problems). To date I have not met anyone who has it
> running on Windows.
> That said, I read your original question. What Steve says is true...
> you can run both perl and php mapscripts, but the question asks
> itself... why? I don't know of anything you can do in one you can't in
> the other. If it is all under your control, stick with one...
> php/mapscript is well supported under Windows. The good folks at DM
> Solutions have made wonderful examples available, many other people
> (myself included) have created successful apps... php/mapscript seems
> to be a viable, perhaps the only, solution on windows.
> You want to share more as to why you want to mix perl and php on windows?
> The only
> > installation docs i could find were for unix.
> > thx
> > Paul
> > From: <woodbri at s...>
> > To: "MapServer List EE-mail"" <mapserver-users at l...>; "Paul
> > Dymecki" <millardymecki at s...>
> > Sent: Saturday, March 15, 2003 9:55 AM
> > Subject: Re: [Mapserver-users] perl / mapscript
> > > Yes you can have both running. Remember that mapscript is just a
> > > wrapper to give you programmatic access to Mapserver.
> > > There are examples of Perl/Mapscript on wiki and I'm pretty sure one
> > > of them calls querybypoint (although I haven't verified that).
> > > -Steve W.
> > > On 15 Mar 2003 at 9:24, Paul Dymecki wrote:
> > > > Hi,
> > > >     Conveniently enough i need some help with a perl question
> > > >     regarding php. I was wondering what the best way of calling a
> > > >     mapscript querybypoint function from perl?  My current app is in
> > > >     php but need to communicate with another perl application.
> Is it
> > > >     possible to have both perl-mapscript and php-mapscript
> running on
> > > >     the same server?
> > > > thx for any help,
> > > > Paul
> > Mapserver-users mailing list
> > Mapserver-users at l...
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Mapserver-users at lists.gis.umn.edu
