[Mapserver-users] Re: perl / mapscript
Paul Dymecki
millardymecki at sympatico.ca
Sun Mar 16 23:55:38 EST 2003
Well the scenario is this: There are points(lat/lon) entered by individuals
as to siteings of a particular plant species. A quality assurance
program(perl script) is periodically run to determine if there are any
points located outside of their known regions(vegetation polygons). Write
now i'm takeing the simplistic approach and creating a command line php
script that takes in a lat/lon spits out a polygon name. I'm just haveing
issues with command line / mapscript.
Paul
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Sunday, March 16, 2003 11:18 PM
Subject: [Mapserver-users] Re: perl / mapscript
> --- In mapserver-users at yahoogroups.com, "Paul Dymecki"
> <millardymecki at s...> wrote:
> > Well actually i may be makeing this more complicated then it needs. I've
> > built a phpmapscript application containing vegetaion
> zones(polygons) around
> > the country. There is a larger perl application(not under my care) that
> > will pass me a lat/lon.
> this larger perl app... is this a mapserver app? if yes, then it is
> running on unix, because perl/mapscript is possible only on unix
> (afaik). If not, then how do you query it? Is it a pure perl app
> accessing a database? In which case you could simply access the
> database directly from PHP.
> See, the problem is not that you can run perl/mapscript and
> php/mapscript simultaneously. The problem is whether you can run them
> in the same script. On the server, the script has to be interpreted by
> either the PHP interpreter, or by the Perl interpreter... can't do
> both. One or the other. What you can do is have the Perl script
> construct a PHP script that you then run from the web. In which case
> you would build a script with the lat/lon values filled in. But, yes,
> this could be complicated.
> Care to give more details?
> >I then have to query and return which vegetation
> > zone this point resides in. So the script would be a backend one
> with no
> > user/map interaction at all. Would that be possible.
> > Paul
> > From: "pkishor_98" <pkishor at g...>
> > To: <mapserver-users at l...>
> > Sent: Sunday, March 16, 2003 9:43 PM
> > > > HI Steve,
> > > > Do you know if Perl/mapscript is available on windowsXP?
> > > afaik, perl/mapscript only compiles on unix (I believe these a
> > > swig-related problems). To date I have not met anyone who has it
> > > running on Windows.
> > > That said, I read your original question. What Steve says is true...
> > > you can run both perl and php mapscripts, but the question asks
> > > itself... why? I don't know of anything you can do in one you can't in
> > > the other. If it is all under your control, stick with one...
> > > php/mapscript is well supported under Windows. The good folks at DM
> > > Solutions have made wonderful examples available, many other people
> > > (myself included) have created successful apps... php/mapscript seems
> > > to be a viable, perhaps the only, solution on windows.
> > > You want to share more as to why you want to mix perl and php on
> windows?
> > > The only
> > > > installation docs i could find were for unix.
> > > > thx
> > > > Paul
> > > > From: <woodbri at s...>
> > > > To: "MapServer List EE-mail"" <mapserver-users at l...>; "Paul
> > > > Dymecki" <millardymecki at s...>
> > > > Sent: Saturday, March 15, 2003 9:55 AM
> > > > Subject: Re: [Mapserver-users] perl / mapscript
> > > > > Yes you can have both running. Remember that mapscript is just a
> > > > > wrapper to give you programmatic access to Mapserver.
> > > > > There are examples of Perl/Mapscript on wiki and I'm pretty
> sure one
> > > > > of them calls querybypoint (although I haven't verified that).
> > > > > -Steve W.
> > > > > On 15 Mar 2003 at 9:24, Paul Dymecki wrote:
> > > > > > Hi,
> > > > > > Conveniently enough i need some help with a perl question
> > > > > > regarding php. I was wondering what the best way of
> calling a
> > > > > > mapscript querybypoint function from perl? My current
> app is in
> > > > > > php but need to communicate with another perl application.
> > > Is it
> > > > > > possible to have both perl-mapscript and php-mapscript
> > > running on
> > > > > > the same server?
> > > > > > thx for any help,
> > > > > > Paul
> > > > _______________________________________________
> > > > Mapserver-users mailing list
> > > > Mapserver-users at l...
> > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Mapserver-users at lists.gis.umn.edu
