[Mapserver-users] N/A
Angelo CM supernaut at esfera.cl
Mon Mar 17 20:39:42 EST 2003
Hi, i'm getting the following error when try to
edit through php the filter
of the layer:
" Warning: MapServer Error in prep_DB(): Error
executing POSTGIS DECLARE
(the actual query) statement: 'DECLARE mycursor
BINARY CURSOR FOR SELECT
nombre_via::text,asbinary(force_collection
(force_2d(the_geom)),'NDR')
OID::text from vias WHERE (fid_tipo_via) and
(the_geom && setSRID(
BOX3D(-71.67189575 -33.078516666667,-
71.572328225 -33.004)'::BOX3D
find_srid('','vias','the_geom') ))'
Postgresql reports the error 'ERROR: left-hand
side of AND is type 'integer'
not 'boolean' ' "
This is the Layer:
LAYER
CONNECTIONTYPE postgis
NAME "ejes_calles"
CONNECTION "user=postgres password=abc123
dbname=cultursig
host=localhost"
STATUS ON
DATA "the_geom from vias"
TYPE LINE
UNITS DD
SIZEUNITS DD
LABELITEM nombre_via
LABELCACHE ON
TOLERANCE 3
TOLERANCEUNITS PIXELS
CLASS
NAME "ejes_calles"
SYMBOL 0
COLOR 255 108 83
SIZE 1
MINSIZE 1
MAXSIZE 100
LABEL
SIZE SMALL
COLOR 0 0 0
ANGLE AUTO
POSITION AUTO
END
END
END
And this is the code in PHP:
$id_tipo=$myrow[2];
$map = ms_newMapObj("../mapas/valpo.map");
$capa = $map->getlayerbyname("ejes_calles");
$capa->setfilter("\"fid_tipo_via\" =
\"$id_tipo\"");
$image = $map->draw();
$image_url = $image->saveWebImage(MS_PNG,1,1,0);
Where is the error? I'm using the latest stable
versions of PHP, PostgreSQL
Mapserver and Postgis.
Thanks
Angelo Cabrera M.
angelocabrera at vtr.net
+5692215085
Ingeniería Civil Informática
UTFSM
Valparaíso, Chile
