[Mapserver-users] RE: max number of class in a layer / compiling MapServer
Vincent Schut schut at sarvision.com
Fri Mar 21 07:59:29 EST 2003
Arnulf,
You'll have to change MS_MAXCLASSES in map.h to whatever value you want, then
recompile mapserver (if you don't know how to (re)compile mapserver, there's
plenty of info on the mapserver webpage and wikipages).
Regards,
Vincent Schut.
On Friday 21 March 2003 09:24, Arnulf Christl wrote:
> thanks for the help.
> if i may ask, can you tell me how to recompile the mapserver and to set it
> to
> 70 classes?
> Quoting Arnulf Christl <arnulf.christl at ccgis.de>:
> > The no. of classes can be specified in the sources before compiling. The
> > default (in my downloaded win version) is 50 classes only, so you will
> have
> > to recompile mapserver to get your 70 classes running.
> > Arnulf.
> Hi,
> its said to be fairly easy to do and it is all well documented (but I don't
> know how to do it either).
> We are currently migrating from Win to BSD, additionally we are moving to
> new "pysical" rooms, so currently we have no environment for compiling.
> I am not much help at the moment. Hopefully somebody else can help you.
> Arnulf.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________
Vincent Schut (schut at sarvision.com)
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
