[Mapserver-users] querymap
Lowell Filak
lfilak at medinaco.org
Thu Mar 27 08:50:07 EST 2003
Can you explain a little more of what your trying to do?
I believe that the QueryMap Object in both the mapfile & mapscript are intended for displaying query results.
If you have a QueryMap object in the mapfile and are trying to draw it via mapscript but it is not being drawn you may want to make sure that the status is set to 'on'.
If the QueryMap is being drawn but without the selected objects being hilited you may want to verify that the style is set to 'hilite'.
HTH
Lowell F.
The following message was sent by Sven Jacobi <jacobi at dfki.de> on Thu, 27 Mar 2003 09:34:47 +0100.
> Hi Michael,
> the function "mymapobj.drawQuery()" draws a specified query, for
> example by a specified attribute, but it won't return the hilited
> "QUERYMAP" of the mapfile.
> I think I have to write a script which gets into the specified
> activated layer and returns the object I want to hilite, for
> example a certain forest area.
> But anyway, thanks for your advice.
> Best regards,
> Sven
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
