[Mapserver-users] multiple request in one layer
Smith, Michael ERDC-CRREL-NH
Michael.Smith at erdc.usace.army.mil
Thu Mar 27 09:03:56 EST 2003
Thilo,
you need your class expression column available from the DATA select statement. Try
DATA "GEOM, KARTENSIGNATURNUMMER FROM (select STREETS.geom, STREETS.KARTENSIGNATURNUMMER from STREETS union all
select PATH.geoloc, PATH.KARTENSIGNATURNUMMER from PATH)"
The key info is the invalid column name error. Any class expressions need to be selectable from the data statement.
Mike Smith
email: michael.smith at erdc.usace.army.mil
RSGISC
ERDC - CRREL
Hanover, NH 03755
(603) 646-4765
-----Original Message-----
From: Schlemmer Thilo [mailto:Thilo.Schlemmer at blva.bayern.de]
Sent: Thursday, March 27, 2003 8:47 AM
To: Mapserver-Users-Request at Lists. Gis. Umn. Edu (E-Mail)
Subject: AW: [Mapserver-users] multiple request in one layer
> please always reply to all when using a mailinglist; others might have
> more
> knowledge and join the discussion, or learn from it...
sorry :) thanks for your hint...
> Or course a workaround is to just create this table outside mapserver. But
> if
> you have dynamic data this might not be a good solution. Maybe a view is
> an
> option? But this is outside of my sql knowledge.
> Why not using 2 layers, actually?Eventually you can group them into the
> same
> group and have them displayed in the legend as one group instead of 2
> layers,
> if that's the bottleneck...
i guess i have to explain, what i need...
actually i have a dynamic mapfile (generated with jsp/javabean )
with 9 or more Layer. Each Layer have a oraclespatial connection to get the
data. Three or more Layers are needed to get the same column and the same
type (Line) from different tables.
I thought, that i could make my requests more performant, if i
receive the data in one layer .
I'm surprised, that my statement is in oracle ok but in mapserver
not.
I have not so much knowledge and experience in oracle/sql and i am
truely not a mapserver-expert.
with the last tip from michael I get this message:
msOracleSpatialLayerWhichShapes(): ORA-00904: invalid column name.
SQL statement: SELECT rownum, KARTENSIGNATURNUMMER, GEOM FROM (select
STREETS.geom from STREETS union all select PATH.geom from PATH
)sdo_filter(geoloc,mdsys.sdo_geometry(.......)='TRUE'
is it possible, that the WHERE-Term is missing before
sdo_filter...blabla?
here my mapfile-sequence:
LAYER
CONNECTIONTYPE oraclespatial
CONNECTION"something/somewhere at else"
NAME "STREETS"
DATA "GEOM FROM (select STREETS.geom from STREETS union all
select PATH.geoloc from PATH)"
TYPE LINE
FILTER "sdo_filter(GEOM, mdsys.sdo_geometry(.......) = 'TRUE' "
CLASS
EXPRESSION ('[KARTENSIGNATURNUMMER]' eq '3100' )
SYMBOL "circle"
thanks for your patience
Thilo
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
