[Mapserver-users] Getting attributes of tiled shapefile data
Sean Gillies
sgillies at frii.com
Tue Oct 7 22:09:30 EDT 2003
Steve,
Thanks for the tip! There's also a 'values' attribute for the
SWIGged shapeObj, but it's not as useful since it returns a
SWIG pointer rather than a hash. You did point me in the right
direction.
Best I could come up with uses Python's list comprehensions.
res = layerobj.getResult(j)
shp = layerobj.getShape(res.tileindex, res.shapeindex)
items = [layerobj.getItem(i) for i in range(layerobj.numitems)]
values = [s.getValue(i) for i in range(layerobj.numitems)]
cfcc = values[items.index('CFCC')]
Not as nice as PHP ... yet one more thing to catch up with.
thanks again,
Sean
On Tuesday, October 7, 2003, at 07:39 PM, Stephen Woodbridge wrote:
> Sean,
> In PHP mapscript, I do it like this:
> $res = $layer->getResult($j);
> $shp = $layer->getShape($res->tileindex, $res->shapeindex);
> $cfcc = $shp->values['CFCC'];
> where CFCC is the field name.
> -Steve W.
> On 7 Oct 2003 at 19:03, Sean Gillies wrote:
>> I'm using a layer with tiled shapefile data in a MapScript app. When
>> using the query* methods I get set of results and each result has
>> tileindex and shapeindex attributes so that I can get get the
>> appropriate shape from the shapefile.
>> However, how about the shape attributes? With untiled data in one
>> shapefile, I'd just get the appropriate record from the single dbf
>> file using dbflib (Python) or XBase (Perl). But now that the
>> attributes are spread across N dbf files, I'm at a loss on which dbf
>> file and which record given the pair of tileindex and shapeindex.
>> Perhaps it's possible to access the result.tileindex (or tileindex-1)
>> record of the layer's tileindex dbf file to find the appropriate
>> shapefile and then get the result.shapeindex record from that
>> shapefile's dbf? I'd be grateful to hear about a less convoluted way!
>> cheers,
>> Sean
>> Sean Gillies
>> sgillies at frii dot com
>> http://www.frii.com/~sgillies
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
