[Mapserver-users] Re: Perl Mapscript Setup errors : tricky windows problem
Puneet Kishor
pkishor at geoanalytics.com
Tue Oct 28 17:35:55 EST 2003
> -----Original Message-----
> From: Stephen Clark [mailto:stephen.clark at focus.ca]
> Sent: Tuesday, October 28, 2003 5:30 PM
> To: Puneet Kishor; mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Re: Perl Mapscript Setup
> I am trying to get Perl Mapscript to work on Windows.
> I was hoping someone might have some suggestions for a good
> set of setup
> steps that will work on Win2k , Perl 5.8.0 and Apache 2..0.46
As I said, afaik, no one has thus far compiled Perl/Mapscript on
Windows. The issue lies with Swig (I daresay I would like to see
Perl/Mapscript work on Windows. I spend a fair amount of time on
Windows, and would be nice to use some of my time there to work on
Mapserver).
> As far as the Cygwin setup :
> I have installed Cygwin but cannot get any of the executables
> compiled under
> cygwin to work with my Perl scripts. I think it is the
> compile parameters
> set in the Makefile that are the problem.
> I believe there is a set of parameters that will compile
> executables for DOS
> or i586 or the like but I do not know at this time.
Cygwin is a viable alternative... Essentially you complile Mapserver
with Perl/Mapscript under cygwin, and everything runs happily...
Including PostGIS, if you are so inclined. Instructions are up and about
(see the wiki and other usual locations).
> ----- Original Message -----
> From: "pkishor_98" <pkishor at geoanalytics.com>
> To: <mapserver-users at lists.gis.umn.edu>
> Sent: Tuesday, October 28, 2003 1:46 PM
> Subject: [Mapserver-users] Re: Perl Mapscript Setup errors :
> tricky windows
> problem
> > --- In mapserver-users at yahoogroups.com, "Stephen Clark"
> > <stephen.clark at f...> wrote:
> > > Hi all,
> > > Thanks for the help so far.
> > > I have been having trouble getting Perl to accept the
> mapscript module.
> > > I believe the error is the @inc is not adding the
> mapscript.pm file.
> > > Wher would I look to add the mapscript module to the Perl list of
> > includes.
> > > My specs are:
> > > Win2k
> > > Active perl with Apache build (Perl 5.8.0)
> > you mean to say that you are getting Perl/Mapscript to work on
> > Windows? I thought that was not really possible unless using cygwin.
> > Perl/Mapscript doesn't compile on Windows, afaik.
> > That said, you could anything to c:\perl\lib or c:\perl\site\lib
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
