[Mapserver-users] Oracle Spatial extents
Vladimir Guzmán
bigfoot at main-task.com
Wed Feb 18 12:39:46 EST 2004
Yes, that's what I want.
But when I try it, Oracle says:
ORA-13374: SDO_MBR not supported for geodetic data
In the documentation says:
Usage Notes:
This function is not supported with geodetic data.
What do they mean with 'geodetic data'?
Data with a SRID?
The information in the table is stored with SRID 8307 (WGS84).
Should I change it in order to make it work?
Thanks a lot for your help.
Vladimir Ilich Guzmán R.
http://www.maintask.com
Mills, Daniel wrote:
>what you want is
>SELECT SDO_GEOM.SDO_MBR(c.shape)
> FROM cola_markets c;
>This will give you the mbr (extent) of the shape as a geometry object.
>OR
>CREATE TYPE vertex_set_type as TABLE OF vertex_type;
>Oracle Spatial defines the object type VERTEX_TYPE as:
>CREATE TYPE vertex_type AS OBJECT
> (x NUMBER,
> y NUMBER,
> z NUMBER,
> w NUMBER);
>SELECT c.name, t.X, t.Y
> FROM cola_markets c,
> TABLE(SDO_UTIL.GETVERTICES(SELECT SDO_GEOM.SDO_MBR(c.shape)
> FROM cola_markets c)) t;
>THIS WILL PUT THE VERTICES INTO A TABLE.
>Daniel Mills
>GIS Consultant
>Tel: + 44 (0) 1793 865205
>Fax: + 44 (0) 1793 865001
>E-mail: mills_d at wrcplc.co.uk
>Website: www.wrcplc.co.uk
>-----Original Message-----
>From: Vladimir Guzmán [mailto:bigfoot at main-task.com]
>Sent: Wednesday, 18 February 2004 16:59
>To: David Fawcett; Mapserver-Userlist
>Subject: Re: [Mapserver-users] Oracle Spatial extents
>That's exactly what I need. The problem is that Oracle Spatial does not
>have such a function "extent",
