[Mapserver-users] Oracle Spatial extents
Vladimir Guzmán
bigfoot at main-task.com
Wed Feb 18 13:04:31 EST 2004
Thanks all for your valuable help.
I solved using SRID=1 (Sinusoidal WGS 84) instead of SRID=8307
(Geodetic WGS 84)
I don't know the difference, but now I can get (finally) the geometry's
extents.
Thanks a lot.
Vladimir Ilich Guzmán R.
http://www.maintask.com
Vladimir Guzmán wrote:
> Yes, that's what I want.
> But when I try it, Oracle says:
> ORA-13374: SDO_MBR not supported for geodetic data
> In the documentation says:
> Usage Notes:
> This function is not supported with geodetic data.
> What do they mean with 'geodetic data'?
> Data with a SRID?
> The information in the table is stored with SRID 8307 (WGS84).
> Should I change it in order to make it work?
> Thanks a lot for your help.
> Mills, Daniel wrote:
>> what you want is
>> SELECT SDO_GEOM.SDO_MBR(c.shape) FROM cola_markets c;
>> This will give you the mbr (extent) of the shape as a geometry
>> object. OR
>> CREATE TYPE vertex_set_type as TABLE OF vertex_type;
>> Oracle Spatial defines the object type VERTEX_TYPE as:
>> CREATE TYPE vertex_type AS OBJECT
>> (x NUMBER,
>> y NUMBER,
>> z NUMBER,
>> w NUMBER);
>> SELECT c.name, t.X, t.Y
>> FROM cola_markets c,
>> TABLE(SDO_UTIL.GETVERTICES(SELECT SDO_GEOM.SDO_MBR(c.shape) FROM
>> cola_markets c)) t;
>> THIS WILL PUT THE VERTICES INTO A TABLE.
>> Daniel Mills
>> GIS Consultant
>> Tel: + 44 (0) 1793 865205
>> Fax: + 44 (0) 1793 865001
>> E-mail: mills_d at wrcplc.co.uk
>> Website: www.wrcplc.co.uk
>> -----Original Message-----
>> From: Vladimir Guzmán [mailto:bigfoot at main-task.com]
>> Sent: Wednesday, 18 February 2004 16:59
>> To: David Fawcett; Mapserver-Userlist
>> Subject: Re: [Mapserver-users] Oracle Spatial extents
>> That's exactly what I need. The problem is that Oracle Spatial does
>> not have such a function "extent",
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
