problem with tiled layer
Frank Warmerdam
fwarmerdam at GMAIL.COM
Tue Aug 2 17:10:55 EDT 2005
On 8/2/05, Hunter, David - St. Louis Park, MN <David.Hunter at fnf.com> wrote:
> Should I try and upgrade to 4.6? What would be involved, merely copying
> the contents of the bin directory to my cgi-bin?
David,
Well, that depends on your circumstances. Where you get your
binaries, etc. Generally speaking the .map file and other application
components should be pretty compatible between 4.4 and 4.6 so the
main issue is replacing your binaries and support libraries with a newer
version.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
