ASP.NET and mapscript - unable to load DLL
Ian Erickson
ierickson at ANALYGIS.COM
Fri Aug 19 13:12:24 EDT 2005
Alright,
Perhaps "simple" and "Javascript" are not best paired together like
that. I have not looked at Chameleon, except to say that I installed it
once and had issues with browser compatibility - it had the look and
feel of a "simple Javascript" issue. So no. I'm looking for a little
education as to what is available out there to quickly and easily meet
the needs of those persons or institutions who would like to migrate
from a "Google" solution to an internal one, with little to no software
rewrites.
One thing the Google API does reall well, is simplify map delivery. The
backend server stuff - people don't care. But a mediocre web designer
should be able to use the "MapServer Javascript API" to build a mapping
site in a few minutes. Some would argue that Google does not subscribe
to OGC standards, and it's not flexible enough, but given their ( - what
seems to me - ) overnight success, Google is setting the standard in
many ways.
I have considered such an effort on my own, and the ka-Map interface is
really very nice (very "Googleesque") but I don't want to re-invent the
wheel....
Abe Gillespie wrote:
>Hah, you wrote "simple" & "javascript" in the same sentence! :)
>Joking aside, you mentioned ka-Map ... I assume you've looked into Chameleon?
>-Abe
>On 8/19/05, Ian Erickson <ierickson at analygis.com> wrote:
>>Following this thread, I had to ask the following question:
>>I know the mapping (and non-mapping) world is wrapped up in Google. Is
>>there any effort on the part of this community to write a pure
>>Javascript library that mirrors the functionality present in the Google
>>API? I am aware of the ka-Map project but have not investigated it to
>>the level to know whether or not a simple <div> element is enough to
>>encapsulate the mapping interface. Any hints or references to ongoing
>>projects to this end would be appreciated!
>>A simple browser-generic Javascript API that leverages the capabilities
>>of MapServer (rather than Google) could go a great distance in winning
>>even wider support for the MapServer project.
>>>Did you move mapscript.dll to system32 as well? The only DLL that
>>>should be in your bin dir is mapscript_csharp.dll.
>>>Suggestions:
>>>1. Write the mapfile by hand with the file streaming objects?
>>>2. Wrap the MapServer CGI executable with ASP.NET (I think someone
>>>did just this some time ago).
>>>3. If this is all you're doing, you *might* be able to get away with
>>>it in ASP.NET. See if there's a way to protect a section of ASP.NET
>>>code with a semaphore or similar construct. Is there something that
>>>protects in the virtual thread environment?
>>>-Abe
>>>On 8/19/05, Mike Boos <mboos at augsignals.com> wrote:
>>>>I tried moving the dlls to the system32 directory, but that doesn't have
>>>>any effect (am I missing any other dependencies?)
>>>>Unfortunately, I'm kind of stuck with ASP.NET, as that's what the rest
>>>>of the site relies upon. I'm trying to improve the present setup which
>>>>involves sending a request to a C++ CGI program which writes a map file
>>>>to the hard disk and forwards the request to mapserv.exe. If you'd ask
>>>>me, that's a bit of a kluge, and without Mapscript, all I could do to
>>>>improve on that would be to take out the C++ program and have the map
>>>>file generated from within the ASP.NET program itself. Can you think of
>>>>a better way to accomplish the same task?
>>>>Mike
>>>>>Placing the depended-on DLLs into the bin dir will do nothing. I
>>>>>assume you're on a windows box. Therefore the easiest way to take
>>>>>care of this is by placing all the DLLs (except for map_script) into
>>>>><windows>\system32 where <windows> is the system windows directory
>>>>>(c:\winnt, c:\windows, etc.).
>>>>>With that said, you're entering a world of pain by using C# map_script
>>>>>in ASP.NET. Much of the map_script DLL is thread unsafe, that
>>>>>combined with ASP.NET's supremely weird threading model (e.g. virtual
>>>>>threads), you're going to encounter a plethora of problems. This is
>>>>>why you almost never see MapServer + ASP.NET discussion threads.
>>>>>To get more info, search the archives. You should find ten or so
>>>>>messages about this topic.
>>>>>-Abe
>>>>>On 8/18/05, Mike Boos <mboos at augsignals.com> wrote:
>>>>>>Hello
>>>>>>I'm trying to run Mapscript using the SWIG C# bindings on an ASP.NET
>>>>>>server. I compiled the 4.6.0 version of MapServer and have placed what I
>>>>>>believe to be the appropriate dependencies (mapscript_csharp.dll,
>>>>>>mapscript.dll, libmap.dll, bgd.dll, gdal12.dll, pdflib.dll) in the bin
>>>>>>directory on my server. It is appears to be finding
>>>>>>mapscript_csharp.dll, but is having trouble finding mapscript.dll or one
>>>>>>of its dependencies. I am seeing the following error message:
>>>>>>Server Error in '/' Application.
>>>>>> /Unable to load DLL (mapscript)./
>>>>>>* Description: *An unhandled exception occurred during the execution of
>>>>>>the current web request. Please review the stack trace for more
>>>>>>information about the error and where it originated in the code.
>>>>>>* Exception Details: *System.DllNotFoundException: Unable to load DLL
>>>>>>(mapscript).
>>>>>>Am I missing a dependency? Or do I need to set some configuration option
>>>>>>or place the files elsewhere?
>>>>>>Thanks!
>>>>>>Mike Boos
>>Ian Erickson
>>AnalyGIS, LLC
>>http:// www.analygis.com
Ian Erickson
AnalyGIS, LLC
