Using the 4.x Tutorial
Pericles S. Nacionales
naci0002 at UMN.EDU
Fri Dec 9 16:04:46 EST 2005
Brian,
There's a link to download the tutorial (which includes the data) at the
bottom of the page but since the official tutorial site isn't ready yet,
I have to limit access to the current site (as you'll notice it's
sitting on a different domain). The official site will hopefully go up
sooner than later. ;)
-Perry
Brian Peschel wrote:
> Ok, argueably, the tutorial doesn't help much without the data. When
> something doesn't work is that because (for example) the scale of my
> data is drastically different than the tutorial data. <shrug>
> - B
> Sears, Jeremy wrote:
>> Quoting From http://hypnos.cbs.umn.edu/tutorial/ ...
>> " The dataset used in this tutorial was taken from the U.S.
>> Department of
>> the Interior's National Atlas of the United States. You can visit
>> their web
>> site at http://www.nationalatlas.gov."
>> and continues to say ..
>> " When using this tutorial, you are encouraged to use your own dataset."
>> Best Regards
>> Jeremy
>> -----Original Message-----
>> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
>> Behalf Of Brian Peschel
>> Sent: December 9, 2005 12:09 PM
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: [UMN_MAPSERVER-USERS] Using the 4.x Tutorial
>> Being the newbie I am (and from advice from the DEV list), I went to
>> go run
>> through the tutorials. So, I started with the first one:
>> and I am missing something obvious. Where do I get the data to use
>> for this
>> tutorial? I can't seem to find any refernece to it. Under the
>> 'Tutorial
>> Data' section, I see that the author got it from nationalatlas.gov,
>> but no
>> link to the data I need to run through the tutorials. Any idea where
>> I can
>> get the data? I assume it isn't the 'demo' you can download with the
>> source
>> for MapServer as the paths are different and I can't seem to find the
>> same
>> files.
>> Thanks in advance...
