WMS doesn't show maps
luca marletta
lucamarle at GMAIL.COM
Mon Dec 12 02:55:32 EST 2005
Thanks Bart for your reply.
On 12/12/05, Eijnden, B. van den (Bart) <b.vdeijnden at agi.rws.minvenw.nl> wrote:
> Can you post one of your LAYER definitions?
here an example
LAYER
NAME "fotogrammetrico"
STATUS ON
TILEINDEX "/var/www/pmapper/comalo/fotogrammetrico.shp"
TILEITEM "Location"
TYPE RASTER
MAXSCALE 3003
MINSCALE 499
METADATA
"DESCRIPTION" "Fotogrammetrico 1:2.000|Fotogrammetrico
1:2.000|Fotogrammetrico 1:2.000"
END
CLASS
NAME "Fotogrammetrico 1:2.000"
END
END
> Also
> 1) check your WMS GetCapabilities response
> (&service=WMS&version=1.1.1&request=GetCapabilities).
If I do the request above in browser I get "mapserv" downloaded and in
Jump it gives "description not provided" error.
> 2) the request you try is not a full WMS request, it misses things like SRS
> and BBOX.
could you give an example of what I miss in .map as you suggested ere above?
Really thanks Bart.
luca
> -----Oorspronkelijk bericht-----
> Hi all,
> I'm new with WMS, never needed before now.
> I've a working application of mapserver in localhost and I'm trying
> now to set it up for working also in WMS server mode.
> I prepared the map ad howto explain but just the annotations layer
> appears. No one shape and no one raster and NO error.
> It seems it's not able to find the data source but in map file there
> is the absolute path.
> Both with jump and browser request I got same results.
> I cannot get it.
> I'm sure there is an easy explanation but I'm going around from long.
> WEB
> TEMPLATE "/var/www/pmapper/map.html"
> IMAGEPATH "/var/www/pmapper/comalo/tmp/"
> IMAGEURL "comalo/tmp/"
> MINSCALE 500
> MAXSCALE 160000
> METADATA
> "wms_title" "WMS CMALO"
> "wms_onlineresource"
> "http://localhost/cgi-bin/mapserv?map=../pmapper/comalo.map&"
> "wms_srs" "EPSG:4326 EPSG:32632
> EPSG:23032"
> "wms_request" "GetMap"
> "wms_server_version" "1.1.1"
> "wms_service" "WMS"
> "wms_bbox" "1.50911e+06 5.10193e+06 1.53447e+06 5.12307e+06"
> "wms_format" "PNG"
> "wms_bgcolor" "0xFFFFFF"
> "wms_transparent" "TRUE"
> "wms_exception" "INIMAGE"
> END # Metadata
> END # Web
> Here my request in browser
> http://localhost/cgi-bin/mapserv?map=../pmapper/comalo.map&SERVICE=WMS&VERSI
> ON=1.1.1&REQUEST=GetMap&LAYERS=igm
luca marletta
