Mapserver bug?
Flavio Hendry
flavio at TYDAC.CH
Wed Feb 9 01:47:44 EST 2005
hi jeff
youare probably using php as a module ... see bug-id 67.
Mit freundlichem Gruss / Best Regards
Flavio Hendry
TYDAC NEWS http://www.tydac.ch/german/index.php?menu=News_actual
############ Mit freundlichen Gruessen / Kind Regards
############ mailto:flavio at tydac.ch
############ TYDAC AG - http://www.tydac.ch
#### #### Geographic Information Solutions
#### #### Luternauweg 12 -- CH-3006 Bern
############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
-----Original Message-----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Date: Tue, 8 Feb 2005 13:59:38 -0500
Subject: [UMN_MAPSERVER-USERS] Mapserver bug?
> I'm pretty sure that this issue i'm having was posted about once
> before a week or two ago by somebody else, but there wasn't much
> response to it and I'm not sure if it is a mapserver bug, or
> something I'm doing wrong, or if there is a workaround for it.
> When my map form submits and is redrawn according to whatever buttons
> the user has clicked (panning buttons, zoom, etc) it will sometimes
> jump back to an old image instead of displaying the image it is
> supposed to be showing. If you then just click refresh in the
> browser, it displays the proper image. At first I thought it was
> some kind of browser caching issue, so I tried all the meta tags and
> http headers I could find to disable the caching of images in my
> application... but that didn't fix the problem. The problem also
> seems to be browser independant as I see the same behavior in
> internet explorer and Mozilla firefox. It also seems to get
> worse over time... when I first load up the browser and go to the web
> page it will work perfectly for a little bit, but after a short time
> it will start showing old images and eventually it will start doing
> it almost every refresh.
> Have any others had this kind of problem, and has anybody found a way
> to fix it or avoid it?
> Thanks for any advice,
> Jeff
