Help setting up MapScript
Rodrigo Severo rodrigo.lists at FABRICADEIDEIAS.COM
Sun Mar 13 05:58:18 EST 2005
Have you built php inside '/tmp/yang169/php-4.3.9'? As far as I remember
you need to 'configure && make' php. No need to 'make install'.
Rodrigo Severo
overbored wrote:
> Hi all,
> I'm trying to set up PHP/MapScript. I am running PHP-4.3.9, but I did
> not install it (I don't have root on this box). So I downloaded the
> PHP-4.3.9 source (for regex), but I run into the following problem.
> config.status: creating mapscript/php3/Makefile
> config.status: creating mapscript/java/Makefile
> gcc -c -O2 -fPIC  -Wall   -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ
> -DUSE_PROJ_API_H -DUSE_WMS_SVR    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_GIF
> -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS        -DUSE_ICONV
> -DUSE_PHP_REGEX -I/tmp/yang169/php-4.3.9/regex/..
> -I/usr/local/include
> -I/home/cc/cs169/sp05/class/cs169-db/local/include
> /tmp/yang169/php-4.3.9/regex/regcomp.c -o
> /tmp/yang169/php-4.3.9/regex/regcomp.o
> /tmp/yang169/php-4.3.9/regex/regerror.c -o
> /tmp/yang169/php-4.3.9/regex/regerror.o
> /tmp/yang169/php-4.3.9/regex/regerror.c:38: error: `REG_OKAY' undeclared
> here (not in a function)
Rodrigo Severo
Fábrica de Idéias
SBS - Ed. Empire Center - Sala 1301 - Cobertura
Fone: (61) 321 1357
Fax: (61) 223 1712
Creativity is no substitute for knowing what you're doing.
