How can I highlight more than one feature in QUERY mode?
Daniele Margotti margottid at COMUNE.LUGO.RA.IT
Sat May 21 04:51:02 EDT 2005
Hi list,
with CGI mode=ITEMQUERYMAP I can produce a map with one highlighted
feature (defined using QITEM, QLAYER and QSTRING).
How can I highlight more than one feature (within the same layer) using
the same syntax (QITEM + QLAYER + QSTRING)?
Is there the possibility to use an "OR condition" or a regular
expression in QSTRING parameter?
Thank you,
    Daniele
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050521/8d9a32e0/attachment.html
