Cleaning the /tmp directory
Ken Lord kenlord at GMAIL.COM
Tue May 24 12:57:41 EDT 2005
I suppose I should give an example of the contents of my .bat file! :)
 del "C:\path\to\tmp\files\*.*" /Q
The .bat file is run by the windows task schedular once a day.
 Cheers,
Ken Lord
Vancouver BC
 On 5/24/05, Ken Lord <kenlord at gmail.com> wrote:
> James,
>  I use the method you mentioned, 'MODE=MAP', to generate snapshots for
> query results. It works great to highlight each individual item returned by
> a map query, placed next each item's attributes.
>  However, Since mapserver 4 and later have come out, often the images fail
> despite the log statement of 'normal execution'.
>  I have simplified the maps as much as possible, and I'm sure that its not
> a lingering syntax difference between 3.6 (where it worked great) and 4 or
> later. The failures are not consistant either. Why they don't either all
> work or all fail, or at least all the same features queried fail
> consistantly? I have no idea.
>  So I'm leary about suggesting people use MODE=MAP for all their maps just
> to keep their temp folder's empty, especially when a simple .bat file can be
> used to empty them regularly.
>  Cheers,
> Ken Lord
> Vancouver BC
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050524/0a2b5355/attachment.html
