problems with running phtml srcipts
Blaise Picinbono
bpicinbono at WORLDONLINE.FR
Fri Nov 4 09:40:17 EST 2005
Le Vendredi 4 Novembre 2005 15:11, Gambin Dejan a écrit :
> Hi,
> I have installed mapserver 4.6 by the ms4w package on my Windows 2000
> machine. The problem is I have a running IIS, and I simply configured
> the Apache to listen on port 8080 to run together with IIS. Everything
> seems ok but I can't run phtml scripts as php files. I have the
> following in my httpd.conf:
> AddType application/x-httpd-php .phtml .php
> Action application/x-httpd-php /cgi-bin/php.exe
> I can run normally the php scripts but I get an empty page when trying
> to open any phtml file. I have also tried with configuring php as apache
> module but the result is the same. ms4w is using Apache 2.0.54 and php
> 4.3.11.
> Any help?
> regards, dejan
I don't know much about IIS. Your Apache config file seems ok. Did you restart
the Apache server so that it read again the config file ?
Did you restart IIS ?
Blaise
