problems with running phtml srcipts
Gambin Dejan
Dejan.Gambin at PULA.HR
Fri Nov 4 09:42:29 EST 2005
Apache yes, IIS no..why should IIS be restarted?
dejan
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Blaise Picinbono
> Sent: Friday, November 04, 2005 3:40 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] problems with running phtml srcipts
> Le Vendredi 4 Novembre 2005 15:11, Gambin Dejan a écrit :
> > Hi,
> > I have installed mapserver 4.6 by the ms4w package on my
> Windows 2000
> > machine. The problem is I have a running IIS, and I simply
> configured
> > the Apache to listen on port 8080 to run together with IIS.
> Everything
> > seems ok but I can't run phtml scripts as php files. I have the
> > following in my httpd.conf:
> > AddType application/x-httpd-php .phtml .php
> > Action application/x-httpd-php /cgi-bin/php.exe
> > I can run normally the php scripts but I get an empty page
> when trying
> > to open any phtml file. I have also tried with configuring php as
> > apache module but the result is the same. ms4w is using
> Apache 2.0.54
> > and php 4.3.11.
> > Any help?
> > regards, dejan
> Hi,
> I don't know much about IIS. Your Apache config file seems
> ok. Did you restart
> the Apache server so that it read again the config file ?
> Did you restart IIS ?
> Blaise
