problems with running phtml srcipts
Blaise Picinbono
bpicinbono at WORLDONLINE.FR
Fri Nov 4 09:48:30 EST 2005
Sorry, as I told you, I don't know anything about IIS, so I can't tell if it
has to be restarted or not. You'd better run gnu/linux, but that's only my
point of view ;-)
It's strange that your phtml page is blank. Did you check the source code of
the page ? What does it tell ?
Blaise
Le Vendredi 4 Novembre 2005 15:42, Gambin Dejan a écrit :
> Apache yes, IIS no..why should IIS be restarted?
> dejan
> > -----Original Message-----
> > From: UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Blaise Picinbono
> > Sent: Friday, November 04, 2005 3:40 PM
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: Re: [UMN_MAPSERVER-USERS] problems with running phtml srcipts
> > Le Vendredi 4 Novembre 2005 15:11, Gambin Dejan a écrit :
> > > Hi,
> > > I have installed mapserver 4.6 by the ms4w package on my
> > Windows 2000
> > > machine. The problem is I have a running IIS, and I simply
> > configured
> > > the Apache to listen on port 8080 to run together with IIS.
> > Everything
> > > seems ok but I can't run phtml scripts as php files. I have the
> > > following in my httpd.conf:
> > > AddType application/x-httpd-php .phtml .php
> > > Action application/x-httpd-php /cgi-bin/php.exe
> > > I can run normally the php scripts but I get an empty page
> > when trying
> > > to open any phtml file. I have also tried with configuring php as
> > > apache module but the result is the same. ms4w is using
> > Apache 2.0.54
> > > and php 4.3.11.
> > > Any help?
> > > regards, dejan
> > Hi,
> > I don't know much about IIS. Your Apache config file seems
> > ok. Did you restart
> > the Apache server so that it read again the config file ?
> > Did you restart IIS ?
> > Blaise
