How to compile MapServer (with ArcSDE)?
Davelaar, Hilbert
Hilbert.Davelaar at WUR.NL
Tue Nov 8 08:11:46 EST 2005
Hi list,
I have MapServer running and until now I only used shapefiles as input. Now I want to make a connection with ArcSDE. The MapServerWiki: MapServerSDE (http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapServerSDE) tells me:
How to make a connection to SDE:
1. Install the SDE C API client libraries for your platform (preferably matched to the server version you are using, ie 8.2 client -> 8.2 server, 8.3 client -> 8.3 server)
2. Compile MapServer with SDE support (see http://mapserver.gis.umn.edu/doc40/unix-install-howto.html for specific details)
3. Define a LAYER block in a MapFile that uses SDE as the CONNECTIONTYPE
I don't know how to perform step 2. I have MapServer running by simply using the MS4W installer but don't know how to compile. Can someone offer me somehelp? Is it possible to enable SDE support with this MS4W-install of MapServer?
Kind regards,
Hilbert Davelaar
