WMS client request method
J. Parapar listario at GMAIL.COM
Thu Nov 10 11:38:24 EST 2005
Frank,
Thanks for the answer.  My problem is with the layers in the client
mapfile. We have several wms layers but i do not know how to indicate
to MapServer to make POST requests to the WMS server (instead of GET
requests). I have found the wfs_request_method parameter but I did not
find a "wms_request_method".
I have made some tests and, as WMS Server, MapServer do supports
URL-encoded POST request.
Thanks again,
Jorge
2005/11/10, Frank Warmerdam <warmerdam at pobox.com>:
> On 11/10/05, J. Parapar <listario at gmail.com> wrote:
> > Hi all
> > Is it possible to set the WMS client request method to POST?  We have
> > a layer with a long SLD_BODY parameter and the web server says that
> > the request is too long.
> Jorge,
> I think POST WMS (and other cgi style requests) have been
> supported by MapServer for a long time.  I will note that it was
> only in March 2004 that the code was modified to support
> posts without CONTENT_LENGTH, but if you are doing this
> from a browser that should not be an issue.
> This is really one of the cases where I would encourage you to
> "just try it" before asking.  If if doesn't work then you can point
> out your problem on the list.
> When I was at PCI I used to get questions all the time about
> whether the software supported a particular format.  My answer
> was, try "File->Open" on it, did that work?
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
