PHP5 mapserver + mapscript
Rob Cermak cermak at SFOS.UAF.EDU
Tue Nov 15 02:52:33 EST 2005
Peter,
We are running Mapserver/Mapscript under apache2/php5 on Mandrake 10.2
(Linux).
We are using a combo of source and source RPMS to get the job done.
Build notes of various parts can be found here:
  http://ak.aoos.org/dev/mapserver.html
Rob
On Thu, 27 Oct 2005, Ing.Peter Misovic wrote:
> Thank to all for your help. I gonna to try it under Linux.
> Nice day.
> Peter
> On 10/27/05, taatuut at planet.nl <taatuut at planet.nl> wrote:
> > Hello Peter,
> > You can use MapServer and MapScript with PHP 5.
> > For Windows you can use the precompiled binaries at
> > http://dl.maptools.org/dl/, latest is mapserver-4.6.1-win32-
> > php5.0.5.zip
> > I don't know if there are any easy-installers for Linux available, the
> > FGS installer from MapTools is for PHP 4
> > (http://www.maptools.org/fgs/).
> > But you can compile all needed things yourself of course, see
> > http://ms.gis.umn.edu/docs/howto/verboselinuxinstall for more info.
> > Also don't forget to search the MapServer mailing list.
> > Regards,
> > Emil
> > ----- Oorspronkelijk bericht -----
> > Van: "Ing.Peter Misovic" <peter.misovic at GMAIL.COM>
> > Datum: donderdag, oktober 27, 2005 1:05 pm
> > Onderwerp: [UMN_MAPSERVER-USERS] PHP5 mapserver + mapscript
> > > Dear all,
> > > at first I start work with I like to know if I can use
> > > mapserver+mapscript with php5.
> > > Thank you to all.
> > > Peter
Rob Cermak : 907-474-7948 : FAX 907-474-7204 : PGP = 0x75869A6E
Alaska Ocean Observing System : Data Management
School of Fisheries and Ocean Sciences : University of Alaska Fairbanks
cermak at sfos.uaf.edu : fnjrc1 at uaf.edu
ED9U1M7P01 at alaska.edu : cermak at alaska.edu
