PHP5 mapserver + mapscript
Ing.Peter Misovic
peter.misovic at GMAIL.COM
Tue Nov 15 03:05:15 EST 2005
Rob,
great, that's the platform I use - MDK 10.2.
Thank you,
Peter
On 11/15/05, Rob Cermak <cermak at sfos.uaf.edu> wrote:
> Peter,
> We are running Mapserver/Mapscript under apache2/php5 on Mandrake 10.2
> (Linux).
> We are using a combo of source and source RPMS to get the job done.
> Build notes of various parts can be found here:
> http://ak.aoos.org/dev/mapserver.html
> Rob
> On Thu, 27 Oct 2005, Ing.Peter Misovic wrote:
> > Thank to all for your help. I gonna to try it under Linux.
> > Nice day.
> > Peter
> > On 10/27/05, taatuut at planet.nl <taatuut at planet.nl> wrote:
> > > Hello Peter,
> > > You can use MapServer and MapScript with PHP 5.
> > > For Windows you can use the precompiled binaries at
> > > http://dl.maptools.org/dl/, latest is mapserver-4.6.1-win32-
> > > php5.0.5.zip
> > > I don't know if there are any easy-installers for Linux available, the
> > > FGS installer from MapTools is for PHP 4
> > > (http://www.maptools.org/fgs/).
> > > But you can compile all needed things yourself of course, see
> > > http://ms.gis.umn.edu/docs/howto/verboselinuxinstall for more info.
> > > Also don't forget to search the MapServer mailing list.
> > > Regards,
> > > Emil
> > > ----- Oorspronkelijk bericht -----
> > > Van: "Ing.Peter Misovic" <peter.misovic at GMAIL.COM>
> > > Datum: donderdag, oktober 27, 2005 1:05 pm
> > > Onderwerp: [UMN_MAPSERVER-USERS] PHP5 mapserver + mapscript
> > > > Dear all,
> > > > at first I start work with I like to know if I can use
> > > > mapserver+mapscript with php5.
> > > > Thank you to all.
> > > > Peter
> Rob Cermak : 907-474-7948 : FAX 907-474-7204 : PGP = 0x75869A6E
> Alaska Ocean Observing System : Data Management
> School of Fisheries and Ocean Sciences : University of Alaska Fairbanks
> cermak at sfos.uaf.edu : fnjrc1 at uaf.edu
> ED9U1M7P01 at alaska.edu : cermak at alaska.edu
