Line Labels (multiple Labels)
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Nov 21 17:02:48 EST 2005
I have asked about this feature in the past. It would be a very nice
feature to have, but it is not available in mapserver yet unless you
want to code it up :) maporama does it and it looks very nice.
http://www.maporama.com/share/
I think it would be great if mapserver supported a more abstract label
positioning grammar like:
LABEL
LABELITEM <field>
LOCATION
POSITION ...
PERCENT_ALONG <float>
SIDE [LEFT|RIGHT|CENTER|INSIDE|OUTSIDE]
OFFSET [X|Y|NORMAL] <float>
END
END
Then you could attach multiple label blocks to a layer to generate the
labels you want. Moving LABELITEM into the LABEL block allows each block
too have its on item field.
This could also be used to display labels along polygon boundaries using
INSIDE|OUTSIDE for things like administrative boundaries.
-Steve
Bob Basques wrote:
> All,
> I think I saw something like this being asked a few months back, but
> haven't found it in a search.
> I need to be able to label a line at both ends and on both sides. Are
> there some techniques to use in MapServer for this? I can generate the
> point locations from other software for the labels, but the dataset
> changes quite frequently and I woulds like to pursue an automated method
> if possible.
> What I'm trying to label is a Street Centerline with the address ranges
> on both ends, we also have a right/left distinction at both ends so that
> I would need a label on each side of the line as well. Needless to say
> the labels would need to align with the line segment as well rotationally
> Even a search keyword would help if someone knows of something in the
> archives.
> Thanks for any info.
> bobb
