Multiple point symbols
Bob Basques bob.basques at CI.STPAUL.MN.US
Fri Sep 2 14:16:36 EDT 2005
this is going to sound wierd, but I want make a grid pattern of of
regularly space grid points.
I have points at equal distances that I want to make appear that they
are a girdded filled poly area.
Does that make any sense?   something like a checkerboard pattern but at
a pixel level to imitate a transparency.
I was just trying to pur two points into a symbol like so:
|            |      O     |
|      O     |            |
Just two points, The symbol would be 2 pixels by two pixels, or some
mutiple of this.  Then if I place two of these point side by side they
would look like a filled patern (a polygon fill) but still be plotted as
points.
points 0 0 END
points 1 1 END
But this doesn't work for a POINT Symbol.  It break when there are two
POINT vaules for a POINT symbol type.
bobb
Stephen Woodbridge wrote:
>We made groupd of trees as an image then applied the image as a symbol
>to a polygon fill. You could do the same for points and by the number of
>points in the image you could get a density. But I'm not sure if this is
>what you need.
>What data type to you want to use to display this with and what do you
>want the display to look like?
>-Steve W.
>Bob Basques wrote:
>>All,
>>More symbol stuff.
>>Is there a way to make a symbol that is basically a group of points?
>>Along the lines of a grid fill pattern, only at the Symbol level?
>>bobb
