php_mapscript; php_sprintf
Christian Schaffer
christian.schaffer at MUENCHEN.DE
Wed Sep 21 06:13:04 EDT 2005
Hi Dave,
dear list,
thanks for the reply.
I called ldd against my mapserv binary as well as against the
php_mapscript.so and set the apache environment to include the
directories ldd gave back. Unfortunately no success - I still get the
same error message.
I didn´t find much about php_sprintf issues in other lists or in google,
so if there´s any other hint, I´d really appreciate it.
Since there have been some articles concerning the Opteron topic on the
list lately, I´d like to answer Dave´s question on the list, too:
In fact, it´s a Sun Fire V20z, which is a 1U box with up to two
Opterons. It´s by definition not one of the new Sun Galaxy boxes, but as
far as I could see, they are not too different. We´re running a bunch of
intranet web services on a HP DL585 (which is a 4U box with up to four
Opterons) for more than a year now. The Sun box is employed for
development and testing purposes, mainly. Personally, I´m more than
satisfied with the performance of both of them as well as with their
reliability.
For details, feel free to contact me off list. I´d be glad to share what
I´ve learned so far.
Thanks again for helping on my php_sprintf issue ;-)
Chris
David W. Banks schrieb:
>>Don´t know, if this is important: I´m on Solaris 10 on AMD64.
>One of the newish sun opteron boxes? How's that working out?
>I'm just guessing but you're apache environment probably needs to have
>LD_LIBRARY_PATH set to include some extra directories. If you run ldd
>on your mapserver binary you'll be able to see where stuff is coming from
>and adjust your apache ENV to fix things.
>Good luck,
>-Dave
>On Monday 19 September 2005 11:55 pm, you wrote:
>>Hi list,
>>I have a little problem running php_mapscript. My mapserver binary works
>>as desired, so I´m positive about my compilation.
>>But when calling phpinfo_mapscript.phtml, my apache throws the following
>>error message:
>>ld.so.1: /opt/csw/apache2/sbin/httpd: fatal: relocation error: file
>>/usr/local/lib/php/extensions/php_mapscript.so: symbol php_sprintf:
>>referenced symbol not found
>>I´d appreciate any hint to solve this issue.
>>Thanks in advance and best regards,
>>Chris
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050921/096bcf44/attachment.html
