MAPSERVER-USERS Digest - 24 Sep 2005 to 25 Sep 2005
(#2005-277)
shailesh gavavthe
sgavathe at YAHOO.CO.IN
Mon Sep 26 11:58:48 EDT 2005
Hi All ,
I am a developing mapserver 4.60 with PHP.
My mapfiles has some polygon layers, Aerial Photos and Line layes.
One of Polygon layer which is Parcel Information covers the size of entire aerial Photos.
I want the Polygon layer (Hollow) and so that it can rest on the top of Aerial Photo.
I am also developing web application.
Could any one let me know, How will i be able to get the Polygon Unfilled(Hollow) and resting on top of aerial Photo..
here is my Map File and the Order of the Layers is the one below..
LAYER # All RASTER Layers TIFFIMAGE begin here ###########################
TYPE RASTER
#MINSCALE 2000
MAXSCALE 20000 #750000
STATUS OFF
NAME "EDWARDS-NorthEast"
DATA "Aerial Photo\edwards_ne_ILS1.tif"
PROCESSING "BANDS=1,2,3"
OFFSITE 255 255 255
END # layer ends here ---------------
LAYER # All VECTOR Layers begins here
NAME Parcel
METADATA
#"DESCRIPTION" "parcel_polygon"
"DESCRIPTION" "Unplatted Parcel"
"RESULT_FIELDS" "PID ParcelName CalAcreage"
END # end of Metadata----------------
DATA "Unplatted Parcel\parcel_polygon.shp"
STATUS DEFAULT
TYPE POLYGON
#MAXSCALE 10000
LABELITEM "PID"
LABELMAXSCALE 16000
TOLERANCE 3
TRANSPARENCY 1000
CLASS
NAME 'Parcel'
TEMPLATE "templates/Parcel.html"
STYLE
#COLOR 255 255 255
SYMBOL 0
COLOR -1 -1 -1
OUTLINECOLOR 0 0 0
END
LABEL # start of label
COLOR 0 0 0
#SHADOWCOLOR 255 255 0
#SHADOWSIZE 0 0
TYPE TRUETYPE
FONT arial-bold
SIZE 8
ANTIALIAS TRUE
ANGLE AUTO
POSITION LC
PARTIALS FALSE
MINDISTANCE 300
BUFFER 0
END # end of label//////////////
END
If i uncomment the OutlinecColor and comment Color , the selected layers becomes polyine.
And when i put Both of them uncommented, the shapefiles is filled polygon.
After that in the web application, the selcted layers is highlighted with filled polygon, But the aerial Photo becomes invisible, because Layer is Polygon and Filled.
I would really appreciate, if some one could have a solution on it.
Thanks in Advance..
SHAIL
Home PG : http:/people.emich.edu/sgavathe
MAPSERVER-USERS automatic digest system <LISTSERV at LISTS.UMN.EDU> wrote:
MAPSERVER-USERS Digest - 24 Sep 2005 to 25 Sep 2005 (#2005-277)
Table of contents:
WMS, convert GetCapabilites XML to Map Context XML
File permissions set randomly on Apache (2)
Re: WMS, convert GetCapabilites XML to Map Context XML (09/25)
File permissions set randomly on Apache (09/25)
Re: File permissions set randomly on Apache (09/25)
Browse the MAPSERVER-USERS online archives. Date: Sun, 25 Sep 2005 21:14:23 +0200
Subject: Re: WMS, convert GetCapabilites XML to Map Context XML
Tom,
thanks for the link. The Caps2Context.xsl is in fact for WMS. There seem
to be just some small discrepancies between the output of the template
and what the MapScript loadMapContext() function requires, but this
needs just slight modification of the XSL.
Armin
Kralidis,Tom [Burlington] wrote:
> The mapbuilder project (http://mapbuilder.sourceforge.net/) has a WFS
> Capabilities to WMC xsl in lib/tool/xsl/Caps2Context.xsl.
> There's one over at
> http://geoservices.cgdi.ca/mapbuilder/lib/tool/xsl/Caps2Context.xsl.
> You can probably modify it for WMS, and hopefully contribute it to the
> project!
> Cheers
> ..Tom
>>-----Original Message-----
>>From: UMN MapServer Users List
>>[mailto:MAPSERVER-USERS at lists.umn.edu] On Behalf Of Armin Burger
>>Sent: Saturday, 24 September, 2005 08:48
>>To: MAPSERVER-USERS at lists.umn.edu
>>Subject: [UMN_MAPSERVER-USERS] WMS, convert GetCapabilites
>>Hi everybody,
>>MapScript offers the nice functionality to add WMS layers via a Map
>>Context XML file.
>>I would like to convert the XML received from a
>>GetCapabilites request
>>into a Map Context XML document and load this Map Context XML file as
>>layers into the map object. I think XSL transformation could
>>be a good
>>solution to do this conversion. Has anybody already worked on an XSLT
>>template to convert the GetCapabilites XML into a Map Context
>>XML document?
>>Armin
Date: Sun, 25 Sep 2005 21:20:51 +0100
Subject: File permissions set randomly on Apache
New to Mapserver and to this list. I've been doing some initial
development on IIS locally and now wanting to move to a remote (virtual)
host running Unix/Apache. Working OK except that the file permissions on
the map image files seem to be created with permissions varying,
apparently at random, so that sometimes they are displayed, sometimes
not.
I've checked the archives but not been able to fin this exact problem
described. Any help very welcome.
Alan Hale
Bryo Software Solutions
Aberystwyth Wales
No virus found in this outgoing message.
Checked by AVG Anti-Virus.
Version: 7.0.344 / Virus Database: 267.11.6/111 - Release Date:
23/09/2005
Date: Sun, 25 Sep 2005 18:14:24 -0400
Subject: Re: File permissions set randomly on Apache
Alan:
Who/what are the file permissions set as? Also, what OS/apache version?
-Prashanth
HTMLX.com
Mapserver Hosting, Mapscript Hosting, PHP Hosting
PostgreSQL w/PostGIS extension enabled Hosting
On 9/25/05, Alan Hale <alan.hale at btclick.com> wrote:New to Mapserver and to this list. I've been doing some initial
not.
Alan Hale
Aberystwyth Wales
23/09/2005
Shailesh gavathe
516 ,St Johns Street,
Apt # 102,ypsilanti,
MI-48197.
Ph : 734-482-0832
URL : http://people.emich.edu/sgavathe
Yahoo! for Good
Click here to donate to the Hurricane Katrina relief effort.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050926/a804ff14/attachment.html
