Polar reprojection (again)
Charlton Purvis
cplist at EARTHLINK.NET
Thu Feb 16 15:18:00 EST 2006
> Under certain application conditions, I need to re-project the map into a
> polar view. To do this I change projection string to
> PROJECTION
> "proj=laea"
> "lat_0=-90"
> END
> This works very well for all of my vector data, but none of my raster data
> appears. The raster data is in AAI/Grid format. Will this raster format
> not re-project? Should I use a different projection string?
What does the PROJECTION of your RASTER LAYER look like? It needs to match
whatever PROJECTION your raster data is in.
MAP
PROJECTION
"proj=laea"
"lat_0=-90"
END
LAYER
TYPE RASTER
PROJECTION
END
END
END
