I look for solution.......
Eduardo Arévalo earevaloch at GMAIL.COM
Wed Jul 19 17:43:25 EDT 2006
greetings steve thanks for the suggestion.
this he is mapfile that is used for example 1.9 of the manual of mapserver
MAP
  NAME           EX1.9_
  IMAGETYPE      PNG24
  EXTENT        166221 -371954 1505849 632767 # LAEA
  #EXTENT         -97.5 41.619778 -82.122902 49.38562 # Geographic
  SIZE           400 300
  SHAPEPATH      "../data"
  SYMBOLSET      "../symbols/symbols35.sym"
  FONTSET        "../fonts/fonts.list"
  WEB
    TEMPLATE  'example1-9.html'
    IMAGEPATH '/ms4w/tmp/ms_tmp/'
    IMAGEURL  '/ms_tmp/'
  END
  # This is the output PROJECTION definition ------
  PROJECTION
    # Projection parameters can be defined in two ways...
    # This is the traditional Proj.4 definition of Lambert Azimuthal Equal-Area
    # projection for the Continental U.S.
    #  "proj=laea"
    #  "ellps=clrk66"
    #  "lat_0=45"
    #  "lon_0=-100"
    # Alternatively, you can specify an EPSG code.
    # This is the EPSG code for Lambert Azimuthal Equal-Area
    # projection for the U.S.
    "init=epsg:2163"
  END
  # Start of LAYER DEFINITIONS ---------------------------------------------
  LAYER # States polygon layer begins here
    NAME         states
    DATA         states_ugl
    STATUS       OFF
    TYPE         POLYGON
    # Here's an example of the input projection definition.
    # EPSG:4326 is code for geographic (latlong) projection
    # using the WGS84 datum.
    # PROJECTION objects within the LAYER object define the input
    # projection--this is the native projection of your data.
    PROJECTION
      "init=epsg:4326"
    END
    CLASSITEM    "CLASS"
    CLASS
      EXPRESSION 'land'
      STYLE
        SYMBOL     0
        COLOR      232 232 232
      END
    END
  END # States polygon layer ends here
  LAYER # MODIS raster layer begins here
    NAME         modis
    DATA         "raster/mod09a12003161_ugl_ll_8bit.tif"
    STATUS       OFF #DEFAULT
    TYPE         RASTER
    PROCESSING   "BANDS=1,2,3"
    OFFSITE      71 74 65
    PROJECTION
      "init=epsg:4326"
    END
  END # MODIS raster layer ends here
  LAYER # MODIS WMS map from JPL (or from USGS)
    NAME         modis_jpl
    TYPE         RASTER
    OFFSITE      0 0 0
    STATUS       OFF #OFF
    CONNECTIONTYPE     WMS
    CONNECTION "http://mapus.jpl.nasa.gov/wms.cgi?"
    METADATA
      "wms_srs" "EPSG:4326"
      "wms_name" "daily_terra" #"global_mosaic" "daily_aqua"
      "wms_server_version" "1.1.1"
      "wms_format" "image/jpeg"
    END
    PROJECTION
      "init=epsg:4326"
    END
  END # MODIS WMS image ends here
  LAYER # States line layer begins here
    NAME         states
    DATA         states_ugl
    STATUS       OFF
    TYPE         LINE
    PROJECTION
      "init=epsg:4326"
    END
    CLASSITEM    "CLASS"
    CLASS
      EXPRESSION 'land'
      STYLE
        SYMBOL     'line5'
        COLOR      32 32 32
        SIZE       1
      END
    END
  END # States line layer ends here
  LAYER # States label layer begins here
    NAME         states
    DATA         states_ugl
    STATUS       OFF
    TYPE         ANNOTATION
    PROJECTION
      "init=epsg:4326"
    END
    CLASSITEM    "CLASS"
    LABELITEM    "STATE"
    CLASS
      EXPRESSION 'land'
      STYLE
        COLOR      -1 -1 -1
      END
      LABEL
        COLOR 132 31 31
        OUTLINECOLOR 128 128 128
        SHADOWCOLOR 218 218 218
        SHADOWSIZE 1 1
        TYPE TRUETYPE
        FONT arial-bold
        SIZE 12
        ANTIALIAS TRUE
        POSITION CL
        PARTIALS FALSE
        MINDISTANCE 200
        BUFFER 4
      END # end of label
    END # end of class
  END # States label layer ends here
  # End of LAYER DEFINITIONS -------------------------------
END # All map files must come to an end just as all other things must come to...
# End of section 1, dude!
the question specifies is as the EXTENT calculates
so that it is different from all the used ones in previous examples
2006/7/19, Steve Lime <Steve.Lime at dnr.state.mn.us>:
> You can send questions to the mapserver mailing list and I'm sure folks
> will help if they can.
> Steve
> >>> Eduardo Arévalo <earevaloch at GMAIL.COM> 7/19/2006 10:17:08 AM >>>
> I am following tutorial of Mapserver written by Pericles S. Nacionales,
> lodged in
> http://hypnos.cbs.umn.edu/tutorial/
> I need to make questions on:
> Section 1
> 1.9 - Intro to MapServer Modes: map and browse
> as I can be put in contact with them ?????
> thanks
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060719/29e706b8/attachment.html
