Please help me with buffer in JavaMapscript!!!!
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Sat Jul 22 05:30:38 EDT 2006
This issue has been fixed very recently. Try 4.8.4 or latest cvs.
Umberto
On 7/21/06, Reyes, Mariano <mreyes at siscat.com.ar> wrote:
> Hi,
> I have ld.so.conf with line /usr/local/lib
> Thank anyhow
> Mariano Reyes
> Buenos Aires, Argentina
> ________________________________
> De: Alejandro Rico [mailto:jarg58 at gmail.com]
> Enviado el: viernes, 21 de julio de 2006 17:29
> Para: Reyes, Mariano
> CC: MAPSERVER-USERS at lists.umn.edu
> Asunto: Re: [UMN_MAPSERVER-USERS] Please help me with buffer in
> JavaMapscript!!!!
> Hi !!!
> try to put in your /etc/ld.so.conf the line /usr/local/lib
> and then run ldconfig, this let mapserver find the libraries needed to
> execute properly.
> Hi,
> I have a problem with shapeObj.buffer( int i ), when call buffer I get this
> error:
> Exception in thread "main" java.lang.UnknownError: GEOS support is not
> available
> My code is:
> pointObj punto = new pointObj( 250, 250, 0 );
> lineObj line = new lineObj();
> line.add(punto);
> shapeObj shape = new shapeObj( mapscriptConstants.MS_SHP_ARCM );
> shape.add( line );
> shapeObj buff = shape.buffer( 200 );
> Then I try compiler mapserver with geos, and in make test of mapscript/java
> I have this message of error:
> # An unexpected error has been detected by HotSpot Virtual Machine:
> # SIGSEGV (0xb) at pc=0x400a89b0, pid=30009, tid=1075228800
> # Java VM: Java HotSpot (TM) Client VM ( 1.4.2_11-b06 mixed mode )
> # Problematic frame:
> # C [libc.so.6+0x729b0]
> Please help me!!!!
> Thank You!!!!
> Mariano Reyes
> Alejandro Rico
