WMS time question
Eijnden, Bart van den (AGI) b.vdeijnden at AGI.RWS.MINVENW.NL
Thu Jul 27 02:58:45 EDT 2006
Hi Assefa,
so e.g. you would have (DD-MM-YYYY):
ROAD_SEGMENT_ID		MIN_DATE		MAX_DATE
1				01-01-2006		01-04-2006
2				01-03-2006		01-06-2006
etc.
So these represent validity, the road segment is valid/existant between MIN_DATE and MAX_DATE.
So if I want a map with the situation of 01-05-2006, 1 would not be on it, but 2 would be.
If I would want a map with the situation of 15-03-2006 until 15-04-2006, both would be on it.
Does this make sense?
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Yewondwossen Assefa
Verzonden: donderdag 27 juli 2006 3:35
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] WMS time question
Bart,
Bart van den Eijnden (OSGIS) wrote:
> Hi list,
> looking through the Mapserver WMS time HOWTO I wondered one thing, it is
> only possible to have 1 timeitem, a DB column which contains the
> date/time. Ofcourse this is pretty okay for satellite images (in a
> tileindex) which are taken every X days/months.
> But what happens to road network segments (geometries in Oracle Spatial
> for instance) which have a minimum date and a maximum date? So you need to
> specify 2 timeitems (one min and one max) for that. Was this use case just
> not implemented?
  What would the min/max date represent : the valid time extents or
simply 2 time fields on which we can do a query ?
The wms request allows to  send a time value that is then compared to
the value inside the timeitem. Would you expect to be able to compare
the time request between the 2 timeitmes defined ?
> Best regards,
> Bart
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
