3D Polygon
Rahkonen Jukka
Jukka.Rahkonen at MMMTIKE.FI
Thu Jul 27 08:50:23 EDT 2006
I suspect your precompiled Mapserver does not support 3D shapefiles. At least my, a bit old MS4W Mapserver does not. You may want to try converting your shapefile to normal 2D shapefile with ogr2ogr by using the switch:
-nlt POLYGON.
Regards,
-Jukka Rahkonen-
Lähettäjä: UMN MapServer Users List puolesta: K S
Lähetetty: to 27.7.2006 14:54
Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
Aihe: Re: [UMN_MAPSERVER-USERS] 3D Polygon
I have tried using TYPE POLYGON in this LAYER but mapserver keeps showing the error message:
msDrawShapes() General error message. Only polygon shapes can be drawn using a POLYGON layer definition.
I am using mapserver version 4.8.4 from the precompiled pack that is distributed from maptools.org. I can use TYPE LINE for the LAYER without getting any error but that doesn't result to the map I want to show.Any ideas?
Thank you for the response!
"Bart van den Eijnden (OSGIS)" <bartvde at xs4all.nl> ??????:
You should just use TYPE POLYGON. Note I think you need Mapserver 4.6 or
greater, best to try with the latest release (4.8.X).
Btw, Mapserver has a compile option determining whether or not it will
pick up Z and M values.
# If you want to use shape Z and M parameter this option must be set.
# It's OFF by default.
#USE_POINT_Z_M=-DUSE_POINT_Z_M
USE_POINT_Z_M=
Best regards,
Bart
K S wrote:
> Hello everybody,
> I have a shapefile which is GEOMETRY: 3D POLYGON. How can i draw
> the layer for this shapefile. To be more specific what would be the
> TYPE of such a layer
> Thank you in advance
> ?????????????? Yahoo!
> ?????????? ?? ?????????? ???? ???? (spam); ?? Yahoo! Mail ???????? ???
> http://login.yahoo.com/config/mail?.intl=gr
OSGIS, Open Source GIS
http://www.osgis.nl
?????????? ?? ?????????? ???? ???? (spam); ?? Yahoo! Mail ???????? ??? ???????? ?????? ????????? ???? ??? ??????????? ?????????
