feature attribute character coding
listuser HH listuser at HERZSYS.DE
Thu Jul 27 09:26:23 EDT 2006
xslove schrieb:
> Hi, my shapefile has character attribute AT1, it has cp1250 coding within dbf
> file.
> When I show this dbf, characters are OK. When I read this data as the
> shapeObj usin mapscript, so getValue return bad coded character. where is
> problem?
> thanks radim
which mapscript do you use? If you use java then this can be a problem
with your system language settings.
How do you "show this dbf"?
Regards
Norbert
