point query for multiple layers {Scanned}
Brent Pedersen bpederse at NATURE.BERKELEY.EDU
Thu Jun 1 16:53:53 EDT 2006
figured it out.
at some point, i put the substitution values for all 3 layers in all
3 query templates. once i
put only the [vars] for a particular layer in its query template
everything works as expected.
thanks for the help.
-brent
On Jun 1, 2006, at 4:38 PM, Siki Zoltan wrote:
> Hi,
> Do you have template for all layers you want query?
> Zoltan
> On Thu, 1 Jun 2006, Brent Pedersen wrote:
>> thanks for the reply,
>> it seems that NQUERY is for returning multiple results for example
>> from a search area (as opposed to a single point).
>> using NQUERY, i get multiple results, but only for the last layer
>> drawn.
>> i want the results of a single point query on multiple layers.
>> am i missing something obvious?
>> -brent
>> On Jun 1, 2006, at 10:10 AM, Matthew Perry wrote:
>>> Brent,
>>>  mode=nquery should do the trick. This will return all the matching
>>> features as defined by their layer templates. In addition you can
>>> set
>>> a WEB->HEADER and FOOTER that will be printed before and after
>>> all the
>>> layer templates.
>>> matt
>>> On 6/1/06, Brent Pedersen <bpederse at nature.berkeley.edu> wrote:
>>>> hi,
>>>> using the mapserver CGI is it possible to do a point query on
>>>> multiple
>>>> layers? im not familiar with templates, but
>>>> i'm using mode=query and sending in the list of visible layers but
>>>> TEMPLATE
>>>> substitution only occurs for the last visible layer.
>>>> i have 3 layers and i'd like each of them to be queried.
>>>> do i need to do this with some code by querying each layer
>>>> independently?
>>>> thanks for any leads. layer defs below.
>>>> -brent
>>>>   LAYER
>>>>     NAME 'FRAP'
>>>>     TYPE RASTER
>>>>     TEMPLATE 'FRAP_query.html'
>>>>     OFFSITE 255 0 0
>>>>     DATA '/opt/web/fire/geoFRAP/firethreat.tif'
>>>>     STATUS OFF
>>>>     CLASS
>>>>       NAME 'NA'
>>>>       EXPRESSION ([pixel] = -1)
>>>>       COLOR 205 204 153
>>>>     END
>>>>  END
>>>>   LAYER
>>>>     NAME 'WUI'
>>>>     TYPE POLYGON
>>>>     TEMPLATE 'WUI_query.html'
>>>>     OFFSITE 255 0 0
>>>>     DATA '/home/bpederse/firedata/CA_WUI'
>>>>     STATUS OFF
>>>>    CLASS
>>>>       NAME 'Lowest'
>>>>       EXPRESSION ([Cal_WUI] > 0)
>>>>       OUTLINECOLOR 55 204 53
>>>>     END
>>>>  END
>>>>   LAYER
>>>>     NAME 'CODES'
>>>>     TYPE POLYGON
>>>>     TEMPLATE 'CODES_query.html'
>>>>     OFFSITE 255 0 0
>>>>     DATA '/home/bpederse/firedata/building_code'
>>>>     STATUS OFF
>>>>     CLASS
>>>>       NAME 'Lowest'
>>>>       EXPRESSION ([Building_c] > 0)
>>>>       OUTLINECOLOR 255 0 0
>>>>     END
>>> Matt Perry
>>> perrygeo at gmail.com
>>> http://www.perrygeo.net
