c#-mapscript: Problem first time calling Map.draw(),
numLayers gets one bigger
Tamas Szekeres
szekerest at GMAIL.COM
Thu Jun 22 07:05:18 EDT 2006
Are you using embedded legend or scalebar?
Tamas
2006/6/22, Christian Wilmes <C.Wilmes at gmx.de>:
> Hi,
> if I'm calling the first time Map.draw(), the mapObj-Attribute numLayers gets raised itself from 0 to 1, 1 to 2, 2 to 3.
> The next times I'calling Map.draw() nothig happens with the numLayers-Attribut.
> I testet it with that 3 cases. What could be the reason for that curious behaviour?
> Best Regards
> Christian
> Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
> Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
