Using SLD with GetLegendGraphic
Michael Schulz mschulz at WEBGIS.DE
Fri Mar 3 03:19:50 EST 2006
yes, mapserver will use the sld also for the legendgraphic. It is
however important that you have a class name defined for the layer to
return a legendgraphic. Some minimal legend configuration should also be
present in the mapfile.
HTH, Michael
Miles Jordan schrieb:
> Hi List,
> Is it possible to make a getLegendGraphic request, using a SLD to define
> the style?
> I'm using the same SLD in a getMap request, which styles the layers
> appropriately, as I am for a getLegendGraphic request, which shows
> nothing. If I don't use the SLD, or use a different value in the <Name>
> element of <NamedLayer>, the default style is shown in the
> LegendGraphic.
> I'm only just starrting to look at mapserver, so I might be missing
> something simple.
> This is the request I'm using:
> http://myserver/cgi-bin/mapserv.exe?map=/ms4w/apps/layers/service/sample
> _collection.map&service=WMS&REQUEST=GetLegendGraphic&VERSION=1.0.0&FORMA
> T=image/png&WIDTH=50&HEIGHT=50&LAYER=Humpback_whale_migration&SLD=http:/
> /myserver/test.sld
> The SLD:
> <?xml version="1.0" encoding="UTF-8"?>
> <StyledLayerDescriptor version="1.0.0"
> xmlns="http://www.opengis.net/sld"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/sld
> StyledLayerDescriptor.xsd">
> <NamedLayer>
> 	<Name>Humpback_whale_migration</Name>
> 	<UserStyle>
> 		<Title>Humpback Whale Migration</Title>
> 		<FeatureTypeStyle>
> 			<Rule>
> 				<LineSymbolizer>
> 					<Geometry>
> <ogc:PropertyName>GEOMETRY</ogc:PropertyName>
> 					</Geometry>
> 					<Stroke>
> 						<CssParameter
> name="stroke">#000000</CssParameter>
> 						<CssParameter
> name="stroke-opacity">1</CssParameter>
> 						<CssParameter
> name="stroke-width">2</CssParameter>
> 						<CssParameter
> name="stroke-linejoin">Round</CssParameter>
> 						<CssParameter
> name="stroke-linecap">Square</CssParameter>
> 						<CssParameter
> name="stroke-dasharray">2.0 4.0 4.0 4.0</CssParameter>
> 						<CssParameter
> name="stroke-dashoffset">0</CssParameter>
> 					</Stroke>
> 				</LineSymbolizer>
> 			</Rule>
> 		</FeatureTypeStyle>
> 	</UserStyle>
> </NamedLayer>
> </StyledLayerDescriptor>
> I'd appreciate any help anyone can offer, thanks.
> Miles Jordan
> Applications Developer
> The Australian Antarctic Data Centre
> [p] +61 3 6232 3486
> [f] +61 3 6232 3359
> [e] miles.jordan at aad.gov.au
> [w] http://www.aad.gov.au/
> ___________________________________________________________________________
>     Australian Antarctic Division - Commonwealth of Australia
> IMPORTANT: This transmission is intended for the addressee only. If you are not the
> intended recipient, you are notified that use or dissemination of this communication is
> strictly prohibited by Commonwealth law. If you have received this transmission in error,
> please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
> DELETE the message.
>         Visit our web site at http://www.aad.gov.au/
Michael Schulz                            mschulz at webgis.de
in medias res  Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66              Tel +49 (0)761 556959-5
79108 Freiburg                      Fax +49 (0)761 556959-6
                www.webgis.de / www.zopecms.de
NEU ++ UMN MapServer Hosting ++ http://www.webgis.de ++ NEU
