C# mapscript...
    Howard Butler
    hobu at IASTATE.EDU
    Mon Mar  6 07:53:26 PST 2006
John,
Grab the build kit.  All of the dependencies have been built
already.  All you have to worry about are gdal and mapserver.
<http://hobu.stat.iastate.edu/mapserver/build_output/mapserver-4.8-msvc71-build-kit.zip>
Make sure to edit nmake.opt for GDAL and make a clean GDAL (and then
do nmake /f makefile.vc install).  Edit nmake.opt for MapServer, make
clean, and make install for MapServer and you should end up with a
csharp directory in ..\bin with the C# mapscript binaries.
Catch me on IRC if you have questions.  Then we can write a doc ;)
Howard
At 09:42 AM 3/6/2006, John Cole wrote:
>Tamas,
>   Thanks for your help, some more questions now :-)
>   I've switched to the nightly.tar.gz (because I couldn't figure out flex
>and bison) but I'm having trouble with libpng.  I've checked their site and
>there isn't a lot of info on building with windows, much less building in
>VC8, how did you do it?  I'm getting the following error trying to build the
>libpng solution
>Error   1       fatal error A1000: cannot open file :
>c:\projects\zlib\contrib\masmx86\inffas32.asm   MASM
>I have the zlib library but that file doesn't exist in it (nor does the
>masmx86 directory).
>   Also, I was the nmake /F Makefile.vc was getting errors on not finding
>bgd_i.lib, so I changed those references to bgd.lib, is that OK?  (it got
>past that).
>Thanks,
>John Cole
>-----Original Message-----
>From: Tamas Szekeres [mailto:szekeres.tamas at FREEMAIL.HU]
>Sent: Friday, March 03, 2006 3:58 PM
>To: MAPSERVER-USERS at LISTS.UMN.EDU; John Cole
>Subject: Re: C# mapscript...
>John,
>The parser and lexer files are not precompiled with the CVS version. You
>have at least 2 options to do:
>1. Use the nightly build instead containing theese files precompiled
>http://cvs.gis.umn.edu/dist/nightly.tar.gz
>2. Download flex and bison
>gnuwin32.sourceforge.net/packages/flex.htm
>gnuwin32.sourceforge.net/packages/bison.htm
>and generate theese files from mapparser.y and maplexer.l
>Best Regards,
>Tamas
More information about the MapServer-users
