"Capturing" mapserver images
Stephen Davies
sdc at SDC.COM.AU
Tue Mar 14 01:41:00 EST 2006
Thanks very much Chris. I shall research your suggestion.
The hurdle that I see is that (currently) the database must be updated
with calculated state data for each timestamp.
Cheers,
Stephen
On Monday 13 March 2006 19:50, chris at narx.net wrote:
> Hi Steve, WMS-Time support is my obvious suggestion for your
> situation.
> Check out http://mapserver.gis.umn.edu/docs/howto/wms_time_support
> for setting up inside Mapserver and also
> http://geoservices.cgdi.ca/mapbuilder/demo/timeSeries/index.html for
> an example of a "pseudo-animation" mapbuilder client which seems to
> fit your requirements quite well.
> Regards,
> Chris
> Quoting Stephen Davies <sdc at SDC.COM.AU>:
> > Greetings.
> > I need to be able to present a series of maps for "time lapse"
> > display.
> > The PostgreSQL database behind the mapserver application in
> > question contains both geometry and time-based attribute values and
> > the map file currently used to display the data uses layers,
> > filters and classes to colour geometries according to current
> > attribute values.
> > The idea is to somehow capture the images showing the geometry
> > states at, for example, noon each day for the past month and then
> > use javascript to display those images as a "movie" similar to
> > those provided by many weather bureaux.
> > I have tried doing it simply by pausing in the browser between
> > repaint requests but there is too much variability between browsers
> > and - in particular - between broadband and dialup users.
> > I know I could achieve the objective by writing a PERL or Java
> > program to emulate a browser, retrieve the output image name and
> > ignore the output but wondered if there were a simpler method such
> > as invoking mapserver in map mode from a shell.
> > Any suggestions and/or advice would be most welcome.
> > Cheers and thanks,
> > Stephen Davies
> >===== This email is for the person(s) identified above, and is
> > confidential to the sender and the person(s). No one else is
> > authorised to use or disseminate this email or its contents.
> > Stephen Davies Consulting Voice: 08-8177
> > 1595 Adelaide, South Australia. Fax:
> > 08-8177 0133 Computing & Network solutions.
> > Mobile:0403 0405 83
This email is for the person(s) identified above, and is confidential to
the sender and the person(s). No one else is authorised to use or
Stephen Davies Consulting Voice: 08-8177 1595
Adelaide, South Australia. Fax: 08-8177 0133
Computing & Network solutions. Mobile:0403 0405 83
