"Capturing" mapserver images
Stephen Davies
sdc at SDC.COM.AU
Tue Mar 14 01:49:22 EST 2006
Thank you Gail.
I think this may well be what I need - though I would probably use PERL
Mapscript rather than PHP because of the need to do a deal of
"off-line" manipulation as well as generating the maps and I feel more
comfortable with PERL for "batch" processes.
I hadn't realised that Mapscript was quite so powerful.
Thanks also for the hotscripts link. I haven't been there before either.
Cheers,
Stephen
On Tuesday 14 March 2006 02:31, Gail Long wrote:
> Stephen,
> I did something similar to what you want to do by showing distrbution
> of some point objects over the period of 6 months.
> I used phpmapscript to generate images based on a postgres query and
> saved them to a location other than the default
> while($queryresults)
> //process the query//
> $counter++;
> $image_url="/var/www/htdocs/imageslides".$image->saveWebImage() .'_'
> . $counter;
> That way I had all of the images in that folder with a suffix of _1
> _2 _3 and so on. Then I use one of about a billion javascript, java,
> or flash slide generators that are prebuilt and very configureable.
> I saved to .gif format for a smaller download and my map "paints"
> over a period of time configured in the slide generator. I'm
> probably going to have a more specific flash slide show generator
> written for me because I'm not that good at it, but for what I think
> you want there are tons of really good alternatives.
> So, prebuild your images, then pass them to a prebuilt package to do
> the display. It saves system overhead and makes it much faster to
> for downloading.
> Here is a list of many slideshow components:
> http://www.hotscripts.com/search/9118335.html
> Most are free and there are some very nice flash show builders as
> well that allow you to pass a list of images to it for display.
> Gail
> Things are only difficult while you don't understand them.
> >Quoting Stephen Davies <sdc at SDC.COM.AU>:
> >>Greetings.
> >>I need to be able to present a series of maps for "time lapse"
> >> display.
> >>The PostgreSQL database behind the mapserver application in
> >> question contains both geometry and time-based attribute values
> >> and the map file currently used to display the data uses layers,
> >> filters and classes to colour geometries according to current
> >> attribute values.
> >>The idea is to somehow capture the images showing the geometry
> >> states at, for example, noon each day for the past month and then
> >> use javascript to display those images as a "movie" similar to
> >> those provided by many weather bureaux.
> >>I have tried doing it simply by pausing in the browser between
> >> repaint requests but there is too much variability between
> >> browsers and - in particular - between broadband and dialup users.
> >>I know I could achieve the objective by writing a PERL or Java
> >> program to emulate a browser, retrieve the output image name and
> >> ignore the output but wondered if there were a simpler method such
> >> as invoking mapserver in map mode from a shell.
> >>Any suggestions and/or advice would be most welcome.
> >>Cheers and thanks,
> >>Stephen Davies
> >>===== This email is for the person(s) identified above, and is
> >> confidential to the sender and the person(s). No one else is
> >> authorised to use or disseminate this email or its contents.
> >>Stephen Davies Consulting Voice: 08-8177
> >> 1595 Adelaide, South Australia. Fax:
> >> 08-8177 0133 Computing & Network solutions.
> >> Mobile:0403 0405 83
This email is for the person(s) identified above, and is confidential to
the sender and the person(s). No one else is authorised to use or
Stephen Davies Consulting Voice: 08-8177 1595
Adelaide, South Australia. Fax: 08-8177 0133
Computing & Network solutions. Mobile:0403 0405 83
