Error load from database
Alexander Rodriguez Torres
atorres at ESTUDIANTES.UCI.CU
Tue Mar 21 11:28:58 EST 2006
I have these error when I load my map from database. Can you help me???
msDrawMap(): Image handling error. Failed to draw layer named 'Contornos'.
prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT contornos::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from contornos WHERE the_geom && setSRID('BOX3D(9387137.4 791043.7018,10119140.81 1522550.8382)'::BOX3D, find_srid('','contornos','the_geom') )'
Postgresql reports the error as 'ERROR: cannot cast type contornos to text '
This is my .map
MAP
NAME "Mapa de la UCI"
STATUS ON
EXTENT 9387137.4 805683.77 10119140.81 1507910.77
SIZE 500 500
SHAPEPATH "./data"
SYMBOLSET "./etc/symbols.sym"
FONTSET "./etc/fonts.txt"
IMAGETYPE PNG
IMAGECOLOR 174 183 207
UNITS METERS
TEMPLATEPATTERN "UCI"
WEB
MINSCALE 259371
IMAGEPATH "C:/temp/"
IMAGEURL "/tmp/"
HEADER "templates/header.html"
FOOTER "templates/footer.html"
END
REFERENCE
STATUS ON
IMAGE "images/keymap.png"
SIZE 88 69
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
MINBOXSIZE 3
MAXBOXSIZE 0
MARKER 0
MARKERSIZE 0
END
QUERYMAP
STATUS OFF
SIZE -1 -1
COLOR 255 0 0
STYLE HILITE
END
# Start of legend object
LEGEND
STATUS ON
IMAGECOLOR 255 255 255
POSITION LL
KEYSIZE 18 12
KEYSPACING 5 5
TEMPLATE "ttt"
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 89
PARTIALS TRUE
FORCE FALSE
END
END
# Start of scalebar object
SCALEBAR
STATUS ON
COLOR 255 255 255
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 0 0 0
UNITS KILOMETERS
INTERVALS 5
SIZE 150 5
STYLE 0
POSITION LL
LABEL
TYPE BITMAP
SIZE SMALL
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
PARTIALS TRUE
FORCE TRUE
END
END
# Start of OutputFormat object
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE PC256
TRANSPARENT FALSE
END
LAYER
NAME "Contornos"
STATUS ON
CONNECTIONTYPE POSTGIS
CONNECTION "user=postgres password=post dbname=siguci host=localhost"
CLASSITEM "contornos"
DATA "the_geom from contornos"
TYPE POLYGON
CLASS
NAME "contornos"
TEMPLATE ""
STYLE
SYMBOL 0
COLOR 0 128 0
OUTLINECOLOR 0 0 0
END
END
Alexander Rodríguez Torres.
Estudiante de Quinto Año.
Universidad de las Ciencias Informáticas.
E-mail:atorres at estudiantes.uci.cu
