Displaying Mapserver raster in ArcMap gives 256 colours
Frank Warmerdam
warmerdam at POBOX.COM
Fri Oct 13 10:39:23 EDT 2006
POWER Brendan wrote:
> I have installed ms4w on a windows box with GDAL, etc... From here I
> created a sample map (mapfile below) sourcing data from ecw images.
> When I use the WMS service via an intranet, I get a full colour image
> through the GetMap &LAYER command, however, when using ArcMap, I only
> get a 256 colour image. Is there something I am doing wrong?
> Any assistance would be appreciated.
Brendan,
It may be that ArcMap picks a different format to fetch. You might
check the logs to see what FORMAT= option ArcMap is using. I think
there are "standard outputformats" still offered even when you declare
your own output format(s) (though I'm not sure about that).
> NAME TestMap
> STATUS ON
> SIZE 640 480
> EXTENT 116 -24 120 -22
> UNITS METERS
> SHAPEPATH "d:\Zone_50"
> IMAGETYPE FCADIType
> OUTPUTFORMAT
> NAME FCADIType
> DRIVER "GDAL/jpeg"
> MIMETYPE "image/jpeg"
> IMAGEMODE RGB
> EXTENSION "jpg"
> FORMATOPTION "INTERLACE=OFF"
> FORMATOPTION "QUALITY=100"
> FORMATOPTION "OUTPUT_TYPE=RASTER"
> END
Note that JPEG with QUALITY=100 is substantially larger than with
QUALITY=95, but is not measurably better quality. The libjpeg docs
discourage use of QUALITY over 95. I recently corrected the GDAL docs
to address this, and to clarify that QUALITY=100 is *not* lossless.
What is OUTPUT_TYPE=RASTER supposed to do?
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
