c#-mapscript, Rasterlayer in Map?
Frank Warmerdam warmerdam at POBOX.COM
Tue Oct 17 11:30:23 EDT 2006
Christian Wilmes wrote:
> Hi All,
> ist there any possibility to find out, if a Rasterlayer is in the Extent of
> a Map. There is just one Layer in my Map and I want to know if the map will
> be blank or the Layer is visible. A possibility is to test each pixel if it
> is transparent or not, but that is not very effectiv. I thought about first
> drawing a map with just one 1x1 Pixel, but if the Extent of the Layer is
> much smaller than the extent of the map the result will be a transparent
> pixel even the Layer is in the extent of the map.
> I tried out the method layerObj.isVisible(), but it doesn't have a look on
> Is there any possibility to find out if a Layer is really visible or just
> getting the extent of the raster-layer in the Reference-System of the map?
Christian,
There is no mechanism to accomplish this through mapscript unless you have
set explicit extents on your layer using metadata or the EXTENT keyword.
It should be possible to use GDAL C# bindings to query extents of a
raster file if you have those bindings available (this may not be trivial!)
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
