Python Mapscript Crashes
Frank Warmerdam warmerdam at POBOX.COM
Tue Oct 17 11:45:22 EDT 2006
Umberto Nicoletti wrote:
> Unfortunately the ability of mapscript to deal with garbage collection
> is still limited.
> For example: the host language (in your case, python) will free an
> object because it is no longer reachable without knowing that
> mapscript still has references to it.
> As soon as mapscript dereferences the pointer a segfault will occur.
> As of now there are some methods that are safe to use in some ways,
> but I can't provide a list right now.
> On 10/17/06, Stéphane COLZY <stephane.colzy at magellium.fr> wrote:
>> Have you already encountered this exception with Python/MapScript :
>> Exception exceptions.AttributeError: "'NoneType' object has no attribute
>> 'currentThread'" in <bound method mapObj.__del__ of <mapscript.mapObj;
>> proxy
>> of C mapObj instance at _10108002_p_map_obj>> ignored
>> I'm using python/mapscript from MS4W 1.19 and Python 2.4.3
Stephane,
I think it would be helpful if you could boil this down to a minimal set
of python mapscript calls to demonstrate the problem and submit this as a
bug report in the mapserver bugzilla.  I am not aware of systematic problems
in garbage collection in MapScript but if there are, a concrete demonstration
would be helpful.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
