Strange map draw issue
Steve Hall steve.hall at MERCATORGEOSYSTEMS.CO.UK
Thu Sep 14 12:55:43 EDT 2006
Sorry Ed, I must have forgotten to put that part in my email.
Yes, a simple refresh of the same map will, 9 times ot of 10, get rid of
the garbage.  But then at a random interval it will reappear (but will
be different garbage).
It's kind of hard for me to "post" the entire app, or allow access,
right now i'm afraid so I appreciate it may be hard for anyone to help,
I as just fishing for ideas really!
Thanks,
Steve
Ed McNierney wrote:
> Steve -
> I actually was asking if the output changed if the SAME map was
> refreshed - don't zoom in, out, or pan, just refresh the image/reload
> the page.  Does the same image request always return the same image?
>     - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA  01863
> ed at topozone.com
> (978) 251-4242
> *From:* Steve Hall [mailto:steve.hall at mercatorgeosystems.co.uk]
> *Sent:* Thursday, September 14, 2006 10:39 AM
> *To:* Ed McNierney
> *Cc:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* Re: [UMN_MAPSERVER-USERS] Strange map draw issue
> Hi Ed,
> Thanks for this.  I may check my label columns in the database for
> NULLs and replace them with an empty string ('') instead.   It looks
> like a classic 'null' issue doesn't it?
> Yup - zoom in, zoom out, pan etc and the garbage generally just
> disappears, or changes its 'content'.   Often the angle is the same
> (suspicious) but sometimes not.....  There aren't any features on the
> angles so i'm not sure if it's a labelling issue or not.  Plus the
> problem only occurs about 1 in 20 or so map draws so is kind of hard
> to get a definite problem case.
> Checkout these additional ones :
> http://demo.mercatorgeosystems.co.uk/tmp/1158243616324003.png
> And just to prove it's not all CA....  ;-)
> http://demo.mercatorgeosystems.co.uk/tmp/1158244089248601.png
> http://demo.mercatorgeosystems.co.uk/tmp/1158244147717403.png
> Thanks Ed,
> Steve
> Take a
> Ed McNierney wrote:
>> Steve -
>> Well, just about anything in California is a little odd.....
>> Are you saying that if you simply refresh the image and re-draw the
>> exact same map you'll see this line of text change?  That's
>> puzzling.  I would speculate that it's a (garbage) text label for
>> some garbage feature - there's some feature that's defective in both
>> location and label (attributes messed up) and that feature is being
>> labeled.
>> The first thing I'd try is to eliminate layers from the image,
>> testing until the garbage goes away.  That could identify the
>> offending layer; if there are multiple classes in that layer, use the
>> same system to identify which class it is.  Then see if that says
>> anything helpful.
>>     - Ed
>> Ed McNierney
>> ed at topozone.com
>> (978) 251-4242
>> *From:* UMN MapServer Users List
>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On Behalf Of *Steve Hall
>> *Sent:* Thursday, September 14, 2006 9:22 AM
>> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
>> *Subject:* [UMN_MAPSERVER-USERS] Strange map draw issue
>> Hi All,
>> I've been using Mapserver for a while now, in a variety of
>> situations, but am seeing a slightly strange behaviour in one of my
>> setups.  Basically i'm getting a line of 'garbage' being drawn across
>> the generated map image.
>> A sample of what I mean is here :
>> http://demo.mercatorgeosystems.co.uk/tmp/1158239461914994.png
>> There is no road feature or other line that should be there, and if I
>> redraw the map the line of garbage will either disappear or change in
>> either length or 'content'.  It doesn't appear all the time, but
>> certainly enough to be annoying.
>> My MapServer version is 4.8.1, running with Apache 1.3.31 on Fedora
>> Core 4.  I've got several other MapServer based configurations on
>> this setup and they're all working fine.   The data source in
>> question is an Oracle 10g (10.1) database which is also used for
>> other systems and seems fine.....
>> Weird eh?  Any suggestions much appreciated!
>> Thanks,
>> Steve H
