How can Create OVF file (for OGR MYSQL connection) interactively
Bart van den Eijnden (OSGIS) bartvde at XS4ALL.NL
Tue Sep 19 03:30:50 EDT 2006
See:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData
Section: Dynamic Control of Virtual Sources
Best regards,
Bart
>  Dear friends;
>  Finally I have solved to read point data form mysql database than draw
> map by using
>  those data.
>  I have created Peak Ground Acceleration (PGA) map for the specified
> earthquake which data are
>  stored in MySql. But I would like to display map for all earthquake which
> are
>  described in the Mysql table as eq-id column.I mean PGA data are stored
> in mysql database.table for several earthquakes
> and one of the column is called EQ_ID which use for the seperate PGA data
> from other earthquake like
> EQ_ID            Lon   Lat     PGA
> 200006060242 30.40 32.45 2.5
> 200006060242 30.41 32.46 2.6
> 200006060242 30.42 32.47 2.7
> 200606071708 38.45 40.98 5.6
> 200606071708 38.46 40.99 5.7
> 200606071708 38.47 41.00 5.7
> 200606071708 38.48 41.01 5.8
>  I have querid mysql database by using ovf file as following
>  <OGRVRTDataSource>
>  <OGRVRTLayer name="acceleration">
>  <SrcDataSource>MYSQL:database,user=user,password=pass_wd,host=100.00.00.21,port=3306,tables=d_pgadata1</SrcDataSource>
>  <SrcSQL>SELECT eq_id,latitude,longitude,acceleration from d_pgadata1
>  where eq_id like '%200006060242%' </SrcSQL>
>  <GeometryType>wkbPoint</GeometryType>
>  <GeometryField encoding="PointFromColumns" x="longitude" y="latitude"/>
>  </OGRVRTLayer>
>  </OGRVRTDataSource>
>  As you see when I create map by layer OGR this will just the eq_id like
>  '%200006060242%'.
>  But I would like to change this eq_id by interactively for example who
> will
>  like to see 200606071708 earthquake PGA map he/she can change sql
> statement in
>  ovf file by using php or html commands from web...
>  Do you have any idea is it possible or not.
>  Please I wellcome any kind of information about it..
>  Thank you
>  Murat
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
