Antialias lines - error
Jennifer Strahan jennifer at GREENINFO.ORG
Wed Sep 20 16:51:04 EDT 2006
Hello Andreas,
Thanks for your response.  I currently have:
MapServer version 4.8.3.
PHP/Mapscript ($Revision: 1.242.2.2 $ $Date: 2006/03/16 21:03:01 $)
GD version  2.0 or higher
I am thinking about upgrading to 4.10 for the
curved label support, but I'll probably wait
until it's out of beta.  Any other suggestions on
how I can get this working without upgrading?
Thanks,
Jennifer
At 01:40 PM 9/20/2006, you wrote:
>Jennifer,
>which version of Mapserver/Mapscript and GD are
>you using? I've myself experienced random
>crashes when trying to use antialiasing with
>Mapserver versions prior to 4.8. Besides, back
>then, even if the map rendered successfully, antialiasing didn't work.
>You should upgrade to the last stable version
>(4.8.4) at least. You might even want to try the new 4.10 beta.
>Best regards,
>Jennifer Strahan wrote:
>>Hello,
>>I would like to use Antialias for some of my
>>line layers.  It works fine for one of my
>>layers (regional trails), but when I use it for
>>another layer (highways), I get this error
>>message:  Premature end of script headers:
>>/var/www/cgi-bin/php.  If the map extent
>>includes the entire highways layer, the map
>>image is generated.  If I try to zoom in, the
>>map image is not generated and I get that
>>error.  Here's the layer definition in the mapfile:
>>LAYER
>>   GROUP "Line"
>>   NAME "Highways"
>>   STATUS ON
>>   TYPE LINE
>>   DATA Highways_dot
>>   TRANSPARENCY alpha
>>   CLASS
>>     NAME "Highways"
>>     STYLE
>>        WIDTH 1.5
>>           COLOR 140 140 138
>>        ANTIALIAS true
>>     END
>>   END #class
>>END # Layer
>>Here's the image output info:
>>OUTPUTFORMAT
>>   NAME png24
>>   DRIVER "GD/PNG"
>>   MIMETYPE "image/png"
>>   IMAGEMODE RGB
>>   EXTENSION "png"
>>END
>>Any suggestions?
>>Thanks,
>>Jennifer
>>Jennifer Strahan (Shanks)
>>GreenInfo Network - 1996-2006: A Decade of Mapping the Public Interest
>>116 New Montgomery  Street   Suite 738  San Francisco CA  94105
>>PH: (415)979-0343 x306    Fax:  415-979-0371     Web:  www.greeninfo.org
>Andreas Albarello
>Analysis & SW Development
>Territorium Online srl/GmbH
>Via Buozzi/Buozzistraße 12 - I 39100 Bolzano/Bozen
>email: andreas.albarello at territoriumonline.com
>web:   www.territoriumonline.com
